Brake pads for Baer rotors?
Old Oct 17, 2011 | 07:47 PM
04gibbstahoe's Avatar
Default Brake pads for Baer rotors?
I just bought a new set of front and rear Baer 14" crossed drilled and slotted rotors for my tahoe and was wondering what pads most are running with these type of aftermarket rotors? Are pads from from the local auto parts store sufficient, or do I need something better? The best pad the local store here offers is a Wagner thermo quiet pad. Any good?
Old Oct 17, 2011 | 09:38 PM
1slow01Z71's Avatar
Tin Foil Hat Wearin' Fool
Hawk ceramics
Old Oct 20, 2011 | 08:29 AM
Anyone else? Also, what is sacrificed by not using a high dollar pad on Baer rotors? Is braking power actually sacrificed, or just bad wear on pad and rotor?
Old Dec 12, 2012 | 07:38 PM
therock's Avatar
How did those crossed drilled and slotted rotors work out for you?
Old Dec 12, 2012 | 08:26 PM
terravast4's Avatar
I am running the alumasport setup and I am using the pads from a 05 chrysler 300 on my 05 sierra and they have far less dust than the baer pads and they seemed to work the same
Old Mar 26, 2013 | 10:55 PM
05ado's Avatar
I have an o5 silverado, and was wondering how you found out a chrysler 300 pads fit on a chevy truck? Why would you use them? I found aftermarket pads create way more dust than oem pads.
Old Mar 27, 2013 | 01:27 PM
therock's Avatar
I'm with you on this one and replying to subscribe.
But dust is not as important to me as performance. I just wash the vehicle often enough
Old Mar 27, 2013 | 11:44 PM
chopperman69's Avatar
EBC pads.
Ran a set of Wagner semi-metallic pads on them once and they were hard on the rotors. At over $200 per rotor, I won't do that again...
Old Mar 28, 2013 | 12:13 AM
SnakeOiler's Avatar
For the Alumasport calipers, Baer says so on their site: Uses the same D1058 pads front and rear, which is also a factory 2005 Chrysler 300c brake pad
If you still have Chevy OEM calipers, then, of course, you still use pads that fit an 05 Silverado
RustyD
May 23, 2016 07:04 PM
turbo6c3
Oct 5, 2015 06:11 PM
KINGCYCLES
Oct 2, 2015 10:21 AM
Noah Burns
Sep 13, 2015 09:28 AM
