bolt in KP components 4-link
Old Oct 27, 2007 | 01:37 PM
02_Orange_D1SC's Avatar
Fastest D1 Procharged Truck
Default bolt in KP components 4-link
have any of you guys used this setup i am thinking of doing this on my truck i will have to run coil-overs what type would you recommend i was thinking of a set of qa1s and this setup comes with a panhard rod theres some welding to do on it but not that much it looks like a bolt on kit probably going to do this when the 6.0 comes in to play and traction is a problem
Old Oct 27, 2007 | 03:02 PM
the bars are somewhat small compared to other companies out there, but they are one of the only bolt on, without making it bolt on yourself kits.
Old Oct 28, 2007 | 07:26 PM
I have the kit on my 04 GMC and its been great so far.I am also using the rear bolt-on Cantilever with air bags.I dont have the traction problems I had with the stock leaf springs.Have not been back to the track with it yet to see what improvement it made.My kit was a total bolt-in.I didnt have to weld anything.
Only suggestion I have is to grease the poly bushings with lube.No where in the instructions does it include this step.
Old Oct 28, 2007 | 07:41 PM
Sport Side's Avatar
I had a friend put in mine a couple years ago, along with a set of QA1 coil-overs. I'm still experimenting with springs, trying to get it to ride the best. Traction has never really been a problem for me, but with the right tire and track prep, most people wont have traction problems at our power levels.
Old Oct 28, 2007 | 10:02 PM
sport side did you use a bolt on 4-link or did you do a weld on and what tipe of coilovers did you use
Old Oct 29, 2007 | 03:06 PM
03chevy5.3rcsb's Avatar
Chassis Engineering around $1200 w/ qa1 coilovers included, some welding required. Not a bad deal if you ask me. eventually I'll be going this route.
Old Nov 5, 2007 | 01:43 AM
IslandTahoe's Avatar
What can be done about sway bars for street use or does the four-link (+1) take car of the twisting movement also?
flatblack83
Jan 3, 2026 07:10 PM
mikeyjm1
17
Oct 29, 2015 11:04 PM
chvy=power
Sep 8, 2015 11:06 AM
hackrst
Sep 2, 2015 05:27 PM
