Bleeding an 01 Silverado cultch system
Old Jun 11, 2015 | 11:32 AM
SLOPONY's Avatar
Default Bleeding an 01 Silverado cultch system
Ok so I have air in my lines on an 01 Silverado 1500 clutch system.
No leaks in any part of the system.
NEW master installed, and still cant get it bled out. I have tried the push clutch, open bleeder, close bleeder, repeat...
I also gravity bled a half a quart through it. And I also tried reverse bleeding with gravity.
It just simply has air in it, and I can not get it out. Going to try to use the method of: Open bleeder, press pedal to the floor, close bleeder, repeat...
If any one has any tips or tricks, PLEASE let me know. I did search, but maybe i missed something!
Old Jun 14, 2015 | 08:21 AM
SLOPONY's Avatar
Turns out that my pedal assembly was cracked allowing the master to move, and not deliver a full push to the slave. I found this out when the master came flying off of the firewall... new assembly installed, clutch bled, all is well.
Old Jun 14, 2015 | 09:58 AM
George C....'s Avatar
Formerly ScreamingL
i ended up using a Tick performance master cylinder from a vette, takes some modding but is a nice answer for that cheap stock setup when dealing with heavy duty clutches
Old Jun 14, 2015 | 02:02 PM
DAH32's Avatar
Was that piece entirely plastic? I broke my pedal a few years ago and resulted in the pedal just laying on the floor. Im wondering if all the silverado pedal linkage is plastic.
Old Jun 14, 2015 | 02:24 PM
Formerly ScreamingL
All pedals are plastic
The stock master is plastic
Old Jun 15, 2015 | 10:56 AM
SLOPONY's Avatar
George, I plan on taking the broken pedal, and installing a plate where the stock master mounts, adding a spacer, and mounting a tilton master on it. Ill install this when I get ready to put in a T-56 if I keep the standard, and don't swap to an automatic.
Old Jun 15, 2015 | 12:59 PM
Formerly ScreamingL
I had that mod with the firewall played with 2 of 1/8" plates
Old Aug 10, 2015 | 05:58 PM
SLOPONY's Avatar
George, any tips on a solid setup? I am looking to fab something up this winter.
D1SCSS
Jan 25, 2016 10:14 PM
FlowmasterMufflers
Jul 22, 2015 01:29 PM
FlowmasterMufflers
Jul 22, 2015 12:47 PM
Mark_k
Jul 9, 2015 12:37 AM
Deceptarado
Jul 8, 2015 05:24 PM
