Bleeding an 01 Silverado cultch system
Ok so I have air in my lines on an 01 Silverado 1500 clutch system.
No leaks in any part of the system.
NEW master installed, and still cant get it bled out. I have tried the push clutch, open bleeder, close bleeder, repeat...
I also gravity bled a half a quart through it. And I also tried reverse bleeding with gravity.
It just simply has air in it, and I can not get it out. Going to try to use the method of: Open bleeder, press pedal to the floor, close bleeder, repeat...
If any one has any tips or tricks, PLEASE let me know. I did search, but maybe i missed something!
Turns out that my pedal assembly was cracked allowing the master to move, and not deliver a full push to the slave. I found this out when the master came flying off of the firewall... new assembly installed, clutch bled, all is well.
George, I plan on taking the broken pedal, and installing a plate where the stock master mounts, adding a spacer, and mounting a tilton master on it. Ill install this when I get ready to put in a T-56 if I keep the standard, and don't swap to an automatic.
D1SCSS
Jan 25, 2016 10:14 PM
FlowmasterMufflers
Jul 22, 2015 01:29 PM
FlowmasterMufflers
Jul 22, 2015 12:47 PM
