Best tranny cooling procedure?
Old Nov 9, 2008 | 04:01 PM
  #21
MonteCarlo31's Avatar
Originally Posted by performabuilt
My point was the trans will cease making heat when not running. While it will in fact make heat running even in neutral or park, This I have observed on the dyno. With little air flow just setting there spinning yu can in a relativley short period of time reach temps of 160 as I have noted. Now it would be true if you have been running for instance at the track and were above engine temp with the trans idling would get you down to that just running at idle park , And running with just a cooler and no pass through the radiator you would cool down even more if you have good air flow. But perhaps I miss understood I thought what was ask was after driving the truck and when done ready to park should you let it set a idle a bit before turning off to cool down and My answer to that is no,
Of course IMO if you not getting over 230 degrees to start with I wouldn't worry about either and if you are you need more cooler anyway.
I'd agree, i've noticed that w/ my silverado and the e fans, I've noticed w/ the a/c on *or* fans commanded to run the trans stay much cooler, either in traffic or just sitting in the parking lot. I've never been able to tell an exact temp because I have no trans temp sensor on the truck but it does seem to shift better when it's warmed up (over 110 degress and under 180).
Wolftrk99
Dec 3, 2015 08:12 PM
Lthompson
Oct 2, 2015 12:45 AM
carid
Oct 1, 2015 09:22 AM
Wrecker 426
Sep 30, 2015 09:39 PM
sTNT971
Sep 26, 2015 06:27 AM
