Best tranny cooling procedure?
Old Nov 9, 2008 | 09:48 AM
lady3bglover's Avatar
I have e-fans too, and I still have my shroud. It directs the flow of air a little better. Keeps the air directed to the radiator... just a thought.
Old Nov 9, 2008 | 09:51 AM
00ChevyScott's Avatar
Wearin' da big hat
I don't really see how it would help. The fans pull air through the front of the truck to cool the tranny cooler/ac condensor/radiator. The flow of air across the motor in the engine bay has little to do with engine temps IMO. It's all about getting air through the radiator, which with E-fans against the radiator, you no longer need the shroud.
Old Nov 9, 2008 | 09:53 AM
you do what works for you.....
Old Nov 9, 2008 | 01:08 PM
performabuilt's Avatar
LS1TECH & Trucks Sponsor
Originally Posted by MonteCarlo31
I don't think that's a very true statment. Temps will rise to a point, just above ambient air temp when at idle in park/N. However, if your trans was just at 210 degress and you have now run the truck for 5 or 10 min in park you'll see the temp drop quickly as air moves over it. Why do you think in the PCM when the trans goes over temp it states to pull over and idle engine? If you can keep air moving over your cooler the temp will drop to close to the ambient air temp (maybe 10 to 20 degrees above it) at idle.
My point was the trans will cease making heat when not running. While it will in fact make heat running even in neutral or park, This I have observed on the dyno. With little air flow just setting there spinning yu can in a relativley short period of time reach temps of 160 as I have noted. Now it would be true if you have been running for instance at the track and were above engine temp with the trans idling would get you down to that just running at idle park , And running with just a cooler and no pass through the radiator you would cool down even more if you have good air flow. But perhaps I miss understood I thought what was ask was after driving the truck and when done ready to park should you let it set a idle a bit before turning off to cool down and My answer to that is no,
Of course IMO if you not getting over 230 degrees to start with I wouldn't worry about either and if you are you need more cooler anyway.
Old Nov 9, 2008 | 03:02 PM
RandomHero's Avatar
Just a bit of personal experience. My temps will rise as high as 180* around town when I just put the column shifter in 3rd and have it never unlock. The fastest way I've been able to cool it down though is to lock the converter in 4th and just cruise around.
Old Nov 9, 2008 | 03:03 PM
sprayed8's Avatar
I'm with Scott on this one. i see zero reason to keep the shroud on, it just gets in the way when working under the hood. the purpose of it from the factory was not to "direct airflow" but more to ensure the air is pulled from the right place since the fan was positioned away from the radiator. if it was a pusher fan (which would make no sense) then i agree that a shroud would be necessary. however, with the e-fans directly against the radiator, there is no place other than the radiator for them to pull air from.
Old Nov 9, 2008 | 03:07 PM
trever1t's Avatar
2nd fastest 5.3 ECSB
the best way to cool it down is turn off the engine. I don't think any harm comes to putting it away wet, so to speak, or any benefit to cooling it down before shutoff.
Old Nov 9, 2008 | 03:13 PM
RandomHero's Avatar
On the contrary for me. My temps take much longer to lower with it turned off than if I were traveling 70 miles an hour turning 1800 rpms with the converter locked.
Old Nov 9, 2008 | 03:17 PM
trever1t's Avatar
Sure, but if you are at the end of your journey just turn it off, there's no need to drive around JUST to cool it down afaik.
Old Nov 9, 2008 | 03:26 PM
nonnieselman's Avatar
Depends on how hot the temps are and what kinda conditions you are in..
A cooler thermostat sure keeps the temps down if all you have it is the radiator cooling only.
