best tire & size for towing droppped?
I running an 01 ECSB, 4/6 drop, & 18" wheels. My main mission is towing my 5000lb. boat. I just picked up these...
18" X 8.5" what tire size would work without alot of rub? Also, load rating & wet traction is very important. Thanks in advance
Some of the other guys (with lowered vehicles) can corect me if I'm wrong. . . but I would think with that drop you would want to keep the tires completely tucked, especially if towing. With a 5.25" backspace, you are gonna be running a skinny tire (something with a section width of no more than 9"), by my calculations. That around a 225 size tire, which *might* be to skinny for an 8.5" wheel.
A 5.75" (or more) backspace would provide you with better options.
I'm running an 18x8 with 5.5 backspace. So you would be 1/2" farther out than me. You could get by with a 285 depending heavily on the TREAD width of the tire you choose. The SECTION width of the tire won't be what you need for tire rub.
Originally Posted by flyspec14
I am running helper bags, at least they should be installed after this week. I'm thinking like 275/45/18? I thought 5.25" backspacing was pretty optimal?
FlowmasterMufflers
07-30-2015 05:03 PM
