Best 4l80e rebuild kits?
Old Feb 16, 2012 | 05:56 PM
Vince B's Avatar
Yes it will be fine.
Old Mar 5, 2012 | 12:48 PM
tommyboy86's Avatar
Ck Performance is really good plus great pricing and really fast shipping.. call them! Hp ranges... Stock internals - 500, Stock internals plus a 4340 input shaft - 750-800. After that your looking at billet input, intermediate, and a straight cut gear set. Your also going to need a 34 element sprag in anything over the 500hp limit.. This is the stock sprag used since pretty much the end of th the400 years. A 36 element sprag and super drum is always a good idea over 1,000hp and needed in harsh conditions. Stay away from patc! They know nothing about transmissions and are overpriced! The straight cut gear set is good to 1,500hp the 6pinion helical cut is limited to 1,200 based on side to side force. The early overdirve planet assembly is better as it has a larger sprag and better strength and should be used in the newer drum. Oh and full throttle acceleration while in overdrive is no issue..
Old Mar 5, 2012 | 04:47 PM
HIPSI's Avatar
Look into jakes...
Old Mar 5, 2012 | 06:00 PM
Vince B's Avatar
Not sure if I agree with the straight cut planets being stronger. This has been a debate over the years and they have been shot down by some very good builders. There are also many different options for the intermediate sprag for these units. Yes the obvious upgrade is to install the wider 36 element sprag however most of the kits I have seen or used compromise the width of the frictions. Its kind of a double edged sword in this area of the trans depending on what you go with here. There are some guys making drums using the factory INT. clutches and using a custom race. I like this idea and it would be the best option providing the sprag holds up. I to like to use the early OD carrier in vehicles with decent hp but in some cases depending on the core you get you are forced to use what you get or have to change some parts to make it all work. I do feel that a billet input is a good idea in these units if you are locking the converter at WOT or are north of 700rwhp. HTH Vince
Old Mar 28, 2016 | 01:28 PM
SUNMANEAST's Avatar
Registered User
Hi Tim...could you direct me to BlackGMC 4L80e rebuild info. I am in the throws of a rebuild and would like your input and his. Thanks in advance SUNMANEAST. New to the forum and learning the ropes.
Old Mar 28, 2017 | 02:16 PM
e-jihad's Avatar
Registered User
Since I am doing research like you and found the thread I will post it here.
https://www.performancetrucks.net/fo...thread-495992/
Found it by finding the user and looking through his posts.
GXPJAY
Feb 13, 2022 08:15 AM
SleeperGMC
Jul 29, 2015 10:22 AM
JordanH
Jul 14, 2015 03:46 PM
Cowboy17
Jul 9, 2015 08:22 PM
zaathur151
Jul 6, 2015 10:57 PM
