Belltech!!! WTF!!!
Old Jun 28, 2008 | 05:57 PM
fastrt's Avatar
11 Second Truck Club
Angry Belltech!!! WTF!!!
ok guys, I was going to work friday, and I was about to turn into the shop when my truck made a harsh stop. It felt like my trans locked up, while I was slowing down. I put it in reverse, and it felt ok. Then I put it in drive and it felt ok. I pulled into the lot behind the shop and into my bay and put it in the air. I pulled off the right front after hunting down the rattle. This is what I found....
The belltech drop spindles came with a 2" stud to replace the top hub bolt. AND IT SHEARED OFF!!! What kind of crap do they put in those kits.
I found a bolt in the supply room and put it in and then cut off the head of it, and put it back together.
I almost lost my abs sensor, the light came on when all this happened, and a new one is 115 cost plus 10%. I repaired my sensor with super glue and a bolt with a washer to hold it, seein that the broken stud cracked the hoop that the bolt goes thru.
just thought I would share this with ya.
Old Jun 28, 2008 | 06:02 PM
camaro468's Avatar
thats messed up you cant buy anything with out it fing up
Old Jun 28, 2008 | 10:22 PM
budhayes3's Avatar
PT's Slowest Truck
Why does the nut look cross threaded?
Old Jun 28, 2008 | 10:34 PM
trever1t's Avatar
2nd fastest 5.3 ECSB
^^ it sure does. I think I would have freaked if that happened to me, good thing you had access to the shop!
Old Jun 28, 2008 | 10:36 PM
lady3bglover's Avatar
I have a Belltech 2/4 drop and haven't had a problem. I'd call Belltech if I were you.
Old Jun 28, 2008 | 10:37 PM
fastrt's Avatar
because that part came out and lodged between the spindle and the back of one of the wheel studs. the end with the nut was crushed and it bent the end like that. I think that was the sudden stop I felt.
If I had more that my cell phone to take the pics, I could show you.
Old Jun 28, 2008 | 10:39 PM
fastrt's Avatar
I tryed, but they never call back. I wish I would have spent the extra on mcgaughy's.
Old Jun 28, 2008 | 10:55 PM
2001CamaroGuy's Avatar
What stud? I have the belltech drop spindles and mine didn't come with a stud. I reused all the factory hardware.
Old Jun 28, 2008 | 10:59 PM
fastrt's Avatar
I wish mine reused the stock bolts. my kit was not the crap spindle they first came out with , but the next to the newist design.
Old Jun 28, 2008 | 11:10 PM
00Silv4.8's Avatar
wow, thats shitty bro, good luck getting it sorted out. I havent had a problem with my kit either, and hopefully wont
GMCtrk
Jan 27, 2016 06:47 PM
BCraven1018
Nov 2, 2015 07:18 AM
Alco
Oct 4, 2015 06:58 AM
03chevytruck
Sep 14, 2015 09:15 PM
