AWD (NVG 149) 80E Front Driveshaft
Old Jan 27, 2013 | 06:06 PM
TURBHOE's Avatar
What cross member is that? Is it just one for you to cut up and modify?
Old Jan 27, 2013 | 06:12 PM
AKlowriderZ71's Avatar
11 Second Hall Moniter
Not sure if you were asking me or somebody else, but in my pic was a stock 4x4 crossmember. I don't cut them. I add to the back end of it instead, the same way I've seen others on the forum do it. I might have a pic somewhere, not sure.
Old Jan 27, 2013 | 06:13 PM
Originally Posted by 0235SS93
Im interested in this topic, as i have a 2010 silverado 1/2ton 4x4 with the auto mode. And after the 6" lift, my front shaft is a little too short and causing vibes in auto and 4hi. Would love to find a factory replacement.
Your 2010 is a different platform, and the info here most likely will be different than what you need. What transmission and transfer case does your truck have?
Old Jan 27, 2013 | 06:25 PM
0235SS93's Avatar
6L80E trans, but im not sure on the t-case. Just your standard 2hi,4hi,4lo and Auto.
I do know the lift company makes a replacement shaft, which is 31.75" long. So i imagine mine cant be over 29-30".
Old Jan 28, 2013 | 04:08 AM
TURBHOE's Avatar
Yeah that was your pic. I should have quoted it. I've got to get to do doing my homework. Last time I went looking to do this people were cutting out the center section and moving it back.
At least I already have a segment swapped tune, had it made 4-5 years ago. I just never did the swap.
Old Jan 28, 2013 | 08:19 AM
TIM Z's Avatar
11 sec. Truck Mod
Either way you can mod the crossmember , I cut and moved mine . Either way will be fine .
Old Jan 28, 2013 | 11:19 AM
Fugly flux-core wire...
Old Jan 28, 2013 | 11:39 AM
03sierraslt's Avatar
Just wondering who has done the swap that has the NVG-149 T-Case, in my search for finding the correct front driveshaft I have found some interesting things. I have seen most people end up using the GM 15182094 front drive shaft. What I am trying to find out is if anyone has used this driveshaft on a AWD 80 Swap? The AWD front driveshaft is actually a bit shorter then the standard Auto trac one. Based on what I am finding it looks like that 094 shaft will still work but based on measurements it is actually not quite long enough for a standard Auto Trac setup. Naturally there is enough length to the splines that it should still be fine but I am just looking to clarify who has actually done this on a AWD and what front shaft you used. I know AndyC3 has done it and I am waiting to hear back from him.
Anyone? Andy?
Old Feb 3, 2013 | 04:33 AM
iregret's Avatar
Charlie Murphy!
I just finished my 80E and 149 swap. I reused my front driveshaft. It's close though.
Modified crossmember.
Turk55
Sep 11, 2015 11:52 AM
tgui
Aug 11, 2015 08:30 AM
iregret
Jul 27, 2015 10:32 PM
JordanH
Jul 14, 2015 03:46 PM
