ARP 4L80e Flexplate/TC Bolt PN
Old 08-20-2013, 01:57 PM
mdwatts11's Avatar
Default ARP 4L80e Flexplate/TC Bolt PN
I've looked and can't find the part number for the 80e flexplate/spacer bolts. I'm assuming they will be the same price as the oem bolts. Might as well get arp instead.
Also the arp 80e TC bolts if anyone has the part number.
Thanks in advance.
Old 08-20-2013, 08:49 PM
Gadgetized's Avatar
I believe this is what you are after.
ARP Torque Converter Bolts - M10 x 1.5 Threads, GM 200 & 700, 4L60 & 4L8
Old 08-21-2013, 03:12 AM
Former Vendor
Circle-D's Avatar
Are you using the crank spacer and the flat flexplate? If so the regular ARP bolts are a little on the short side. They are made to fit with just a flexplate, so when you add the spacer you do not get proper thread engagement. So you can use the longer OE style, 19257940. We also make a custom ARP bolt for use with our billet flexplate, which are longer and also work with the OE spacer setup. We have them in stock.
Circle D Specialties - CDS ARP LS Crank Bolts
Chris
Old 08-21-2013, 06:05 PM
mdwatts11's Avatar
Thanks Chris and Gadgetized. I am looking for the bolts for the flat flexplate and spacer. I was flipping through the catalog and noticed they don't even make them in the appropriate length for this setup, which surprised me. I will make it the last thing I buy, and depending on my budget I may just order those from you Chris.
I saw a picture earlier today but I lost it but it was one that Chris posted of the 3 GM bolts and the ARP one you had made. Do you have that so you could post it here?
Old 08-21-2013, 08:12 PM
Former Vendor
Circle-D's Avatar
Here you go...
Old 08-21-2013, 09:38 PM
jschrock's Avatar
TC bolts: ARP-230-7305
Flexplate: ARP-244-2901
Summit part numbers from my swap
Old 08-23-2013, 08:20 AM
mdwatts11's Avatar
Did you get the 2901 to work with the spacer? I thought they were too short.
5.3Okasai
03-09-2022 01:07 PM
lsxperformance
04-20-2016 12:17 AM
slowlsx
08-10-2015 05:33 PM
darnie
08-10-2015 10:25 AM
Ammadien
07-22-2015 08:50 PM
Quick Reply: ARP 4L80e Flexplate/TC Bolt PN
