anything I should remember about removing a tranny?
Well ima try to install my yank this weekend along with shift kit and servo, what is all involved with the removal of the tranny besides unbolting it from the engine? I have never done this before so any help would be appreciated, also any people from houston that may have experience are welcome to come help, ima be doing this, well attempting this on saturday
trans cooler lines can be a real pain in the *** to get off. Use a scribe if you have one (looks like a dental instrument) to get the e-clips off and when you get the lines off put the clips back on, the lines will click right back in that way when you put it back together and you won't lose the little clips.
Make sure your TQ converter is fully engaged on the input shaft.
When doing the shift kit pay very close attention to the directions and take your time.
Dont unbolt it without a jack underneath it!
At least put a helper under it so your tranny doesnt get damaged.
Good luck, wish I could help so that I will know how to do mine. I will be working this Saturday. I will be putting my Caltracs on tomarrow.
Jim
Jim
Oh yea. Go buy some TransGel!!! Or use vaseline. Youll thank yourself when it comes to those checkballs!!!!!
Jim
Jim
go get you a haynes repair manual from autozone,tells how to r/r tranny step by step. Thats what i did, dont need it now got pretty good at it . btw jack the truck up pretty high to have clearance to get it out and a tranny jack helps out lot
Originally Posted by 99Silver6.0
Be sure to fill that converter with fluid night before. Keep checking it. When you think its full. Check it again!!!!!! And be sure you SEAT IT ALL THE WAY!!!! Twist and push, twist and push. Youll feel when its there. (Sounded bad......)
Yeah about 4 feet of extensions is the easiest way to get to it, make sure to remove the crossmember first and let the whole motor and tranny dip down and you'll be able to get to it easier.
Check ***** are like a single ball bearing, there are quite a few of them that are between the valve body and the rest of the trans. If you have the tranny out while doing the shift kit (which i highly recommend) they shouldn't be a problem at all. Your shift kit instructions should tell you where they go when you put it back together.
As said above also, when you fill the TQ converter it will only take a small amount before the fluid is at the top of the snout. You can either wait for it to seep into the converter or you can just tilt it back and forth and it'll go down. You should be able to get a whole quart in it by doing that in about 15 minutes.
