Anyone with a 4/6 drop and 20" wheels
Old Apr 10, 2008 | 05:59 AM
1bad5.3's Avatar
Default Anyone with a 4/6 drop and 20" wheels
1.The offset of my wheels are 14mm. what size tire can I run...Over the winter I will upgrade to 22's. But summer is comming and I want to get the 20's on for now.
2.Also how do I measure backspacing on the wheels???!!
Old Apr 10, 2008 | 09:03 AM
02BlueStepside's Avatar
What is the width of your wheel?
This site will help with measuring backspace/offset
https://www.rsracing.com/tech-wheel.html
Old Apr 10, 2008 | 09:26 AM
xlcooplx's Avatar
As far as tire size, i wouldnt go any larger than a 275/40/20. 275/45/20 will scrub.
Old Apr 10, 2008 | 03:38 PM
1bad5.3's Avatar
[QUOTE=02BlueStepside;3894683]What is the width of your wheel?
I am pretty sure it is 8.5 wide
Old Apr 10, 2008 | 04:20 PM
1bad5.3's Avatar
so you think I will be okay with a 275/40/20? I was also thinking about a 255/45/20 but I do not know what to do!
If it helps I have these on my truck with a 285/50/20 with stock suspension. I wish I knew the back spacing and offset. I tried using the site suggested above and cannot figure it out
Old Apr 10, 2008 | 04:23 PM
RandomHero's Avatar
Matt(xlcooplx) runs 275/40/20's with his rims and I'm 99% sure they are 14mm offset rims.
Old Apr 10, 2008 | 05:29 PM
sickREDsierra's Avatar
my 20's were 285/50 and they scrubbed on the sides at slow speeds, and when i turned, and that was at stock height.
Old Apr 10, 2008 | 06:06 PM
I have 275/40/20 with 5.5 backspacing on a 8.5 inch rim. I had to roll the passenger side rear inner fender a little bit. That's it.
Old Apr 10, 2008 | 06:17 PM
1bad5.3's Avatar
do you know if he had to roll the fenders or cut anything out?
Old Apr 10, 2008 | 06:18 PM
1bad5.3's Avatar
I have not had any problems like that.....
