Anybody strip a converter bolt?
Old Dec 22, 2006 | 02:15 AM
  #31
slowrollin93's Avatar
I actualy had this same problem last night. Only one of them stripped cause i was using the little crappy keys. I switched over the the one i had bought for my brakes that is on the socket and the other two were fine. We just decided to rotate the stripped one down to the bottom access hole and swazawed the torque coverter where the screw goes in since i cared none about the torque converter. It cut right through that piece and only took like 30 seconds.
Jon
Old Dec 22, 2006 | 04:53 AM
  #32
14 Second Truck Club
Now I know an easier way.
Old Nov 1, 2022 | 09:40 AM
  #33
Gentry12's Avatar
Registered User
Default Help
I have a locked up sbc out of a 98 1500 2wd but I got all but one converter bolt one is just so rounded over a wrench won't even bite on to it.
Old Nov 1, 2022 | 10:34 AM
  #34
Atomic's Avatar
I have a gauge for that
Weld a nut on to it
Old Nov 1, 2022 | 10:59 AM
  #35
1FastBrick's Avatar
Custm2500's Rude Friend
Or cut/ torch it off... Fly wheels are cheap to replace.
Old Nov 1, 2022 | 11:30 AM
  #36
Atomic's Avatar
The welder would say weld something and the machinist would say cut something off wouldnt they?
Old Nov 1, 2022 | 12:25 PM
  #37
1FastBrick's Avatar
Thumbs up
Welders use torches occasionally...
Really it depends on what a person has access to as far as tools.
Welders, Torches, and Grinders are prohibited at the Junk Yard. So it's Chisels, Hammers, Sawzall's, Vice grips, Or what ever will get the job done...
Old Nov 2, 2022 | 04:15 PM
  #38
strutaeng's Avatar
5 Year Member
Heat and/or welder. I went to my brother's house to do some electrical work for his new central AC installation.
He's swapping a LQ9 into his 90 C1500 RCSB and had 2 broken exhaust manifold bolts break. Took my little Century Inverter Flux core welder and got them out while grilling some steaks and having some beer. One of them took 4 tries, but came out.
He'd also broken the TV cable bracket hold down on his 700R4 months ago somehow. With it on the ground, I welded a washer on and nut, and that came out too. Hed listed it for sale and a guy had looked at and said I'll be back if you can remove the broken bolt. Dude came back later!
2 years ago when I was removing the transmission on my 99 the oil plug was stripped. I spent 2 days trying to remove that darn bolt. Vice grips, Cobras, those spiral extractors. I finally gave up and drug my stick electrode and extensions under the truck. Welding hood, truck parked on dead grass, and live stinger welding overhead while not catching the darn truck or myself on fire! LOL. I welded a 3/4" nut and out she came! I wasn't asking the darn thing if it was coming out by then!
Old Nov 2, 2022 | 06:42 PM
  #39
RedXray's Avatar
100% Redneck
Originally Posted by strutaeng
grilling some steaks and having some beer...
2 years ago when I was removing the transmission on my 99 the oil plug was stripped...
How did the steaks come out
Those transmission drain plugs are soft, shallow and get rounded off quick even with a tight fit 6pt socket.
easy out = no go
air chisel did the trick
ugly ugly ugly
$6 dollar Autozone universal drain plug with a deep hex much better than GM's... very rare Autozone beats GM
Old Nov 2, 2022 | 07:45 PM
  #40
strutaeng's Avatar
5 Year Member
easy out = no go
ugly ugly ugly
Steaks were tasty! No pics. I was hauling *** welding, then picking up the tools and to be home on time to babysit.
I did reply to the other thread with pictures on this week's grilling. 😁
TarheelZ
Feb 22, 2008 09:18 AM
02 Tahoe on 20s
Dec 30, 2007 07:34 AM
4.8PWR
Jul 12, 2005 10:40 PM
davidtomasiewicz
Mar 12, 2005 09:42 AM
