Any tricks to get a NV3500 to shift better?
Old 04-10-2011, 07:09 PM
blackcash's Avatar
Default Any tricks to get a NV3500 to shift better?
Before anyone says anything, yes a T56 will be replacing it. But for now I'm just wondering if there's a fluid they like better, larger hydraulic line etc. To help get it into gear easier above 4000. Thanks
Old 04-14-2011, 04:16 PM
blackcash's Avatar
No ones got any ideas? Alright I'll just blow it to 57 pieces and throw a T56 in.
Old 04-14-2011, 06:36 PM
PathfinderJr's Avatar
Some say the truck line could benefit from the Drill Mod like the f-body guys do. Honestly, I didn't give my old nv3500 that much of my time before I just went with the t56.
Old 04-14-2011, 10:08 PM
Vince B's Avatar
This seems to be a common complaint from many stick guys. Talked to a dodge guy that said the same thing the other day. If your issue is clutch related then I could see a restriction in the line being an issue. HTH Vince
Old 04-25-2011, 08:36 PM
drperry's Avatar
Get rid of it! lol
My pressure plate springs are kind of fWONked, so it gives me a lot of trouble going into gears... Won't shift into gear above 3500 RPM.
Flog it until it dies
Old 06-19-2011, 08:15 PM
slow1500's Avatar
Any updates on this? I had the same problems...especially after it got hot out. I just bled my lines yesterday and it shifts waaay better now. There was a bit of air and milky(bubbles?) fluid that was cleared out. I had to weld a 8mm socket to a wrench to make a tool to bleed it though. I also trimmed a tad of the rubber floor under the pedal so it would travel farther.
lxcoupe
09-06-2017 08:24 AM
jtphelps289
09-29-2015 12:00 PM
01silvy
09-26-2015 10:20 PM
fortune46x
09-16-2015 08:18 AM
TAPyvehc93
09-14-2015 01:22 PM
Quick Reply: Any tricks to get a NV3500 to shift better?
