Any blown up 6L80E/90E's yet?
Old Jul 21, 2007 | 10:46 AM
ZZebes's Avatar
Originally Posted by h20junkie
How easy would it be to transplant a 6L80E into a 4 speed NNBS truck? Should it be plug and play since the truck will already have the seperate TCM and the transmissions are the same size?
There are programming snaffu's at the moment, the PCM is freaking out because it can't control the tranny and the tranny is not getting the right signals. plus our PCM doesnt have the required areas for the parameters on the 4-5 and 5-6 shift.
Old Jul 23, 2007 | 09:53 AM
h20junkie's Avatar
So in other words it should be figured out by the time my 4 speed ***** the bed?
Old Sep 10, 2007 | 04:59 AM
niugnep's Avatar
This is on a 07 NNBS truck?? I thought the ECU's were the same (E38) and could be programmed? The tranny would need correct TCU of course, I was looking into this and it all looked pretty much trouble free (so I had thought), other than the manual shift mode stuff (have to add hardware to get the button on the shift stalk)...and of course the programming.
Sure be nice to add that thing behind my 5.3 or better yet just do the L92/6L80e....
Thanks
Old Sep 11, 2007 | 02:29 AM
Mr.Slowhoe's Avatar
Someone figure out how to get that trans in my 02 tahoe and I will buy buy buy. Gah a 6 spd tahoe would be so baller!
Old Jan 29, 2008 | 05:37 PM
XLR8NSS's Avatar
Adkoonerstrator
Any horror stories yet?
This thing feels pretty stout, sure hope that is the case.
Old Jan 29, 2008 | 06:36 PM
built408's Avatar
Ive seen a few problems with them but not bad... Had a few that the tcm's going out.. couldn't communicate with it and trans was defaulting into gear.. Also seen one with a huge burr on the 1-2 relay valve causing it to shudder hard under acceleration and when shifting into second gear.. Just replaced the control valve body assembly.. But other than that I havent seen any comming apart yet... Seens to be a good tranny so far...
Old Jan 29, 2008 | 06:48 PM
markislive78's Avatar
13 Second Truck Club
Happy on this end....shifting is smoother now since the TCM updates at the dealership...
Runnin 13.87 on intake,exhaust, HPtuners...
I'm sub'n to this thread I want to know how much they can handle also....thinkin about a blower and don't wanna be the lab rat!
Old Jan 29, 2008 | 07:15 PM
Wide Open's Avatar
I have one in my 00 RCSB behind a L92. I have the problem mentioned above from time to time. I just need to get time with John from Speartech to sort it out. The 6L80E defaults to 3rd gear when it is in limp mode. No need for a converter for sure! The engine revs like it is in neutral with the 4.02 first gear and 3.73's. First gear is done around 35 mph and second at around 60.
Old Jan 29, 2008 | 07:43 PM
dewmanshu's Avatar
Moderately Differentiated
I'll drop the green mini van off and take yours. I'll put it thru the real paces and see what it can handle. (ofcourse after i remove ALL TM) Just how nice I am.
Old Jan 29, 2008 | 07:46 PM
XLR8NSS's Avatar
Adkoonerstrator
I'll be the lab rat.
