Another one of them "Will it fit?" threads
Old Sep 8, 2005 | 02:12 AM
StrokerAce03's Avatar
Default Another one of them "Will it fit?" threads
I'm running 285/50 20 tires right now with about a 2.5 in. drop in the rear. I still have too much of a fenderwell gap and was thinking about dropping it an inch front and rear. After looking at it though, I think I might be able to run a 2/4 drop. My question is does anybody run this combo or know if a 2/4 will work with my tires or will it rub?
Old Sep 8, 2005 | 03:47 PM
Gran Patron's Avatar
Yes, dont worry it will work!!! The rear should be fine and the front should clear out just right!!
Old Sep 8, 2005 | 04:14 PM
Thanks man. I've seen a few trucks with a 2/4 and 22's with close to the same size tire as I got but just wanted to make sure. I probably won't drop it for a little while but wanted to make sure everything was good when I get around to it.
Old Sep 8, 2005 | 04:45 PM
1SlowHoe's Avatar
Destroyer of Transmissions
I have a 2/3 drop and the rear is fine and the front drivers side rubs just enough to hear in a sharp turn. It has now rubbed a hole through the plastic so it doesn't matter But I'm sittin on 24's When I had 22's there was no problem at all.
Old Sep 9, 2005 | 01:10 PM
05hoe's Avatar
What size tires were you running with 22's?
Thanks
Old Sep 9, 2005 | 03:46 PM
1SlowHoe's Avatar
I cannot remember off the top of my head but they were a really low profile. They actually didn't look that good because on a Tahoe you have to fill the wheel well or it doesn't look right. I think they were 285/35/22 or something like that. You can go alot taller than that and still not rub. I think you could go 305/45/22 pretty easy.
Old Sep 10, 2005 | 10:25 PM
TravisH's Avatar
my step-mom has 305/45/22 on her yukon, they barely rub on the plasticinner fender thing.
GXPJAY
Feb 13, 2022 08:15 AM
Ken in AZ
Mar 26, 2016 12:05 PM
Roach Coach
Aug 30, 2015 10:06 PM
markyrgv
Aug 16, 2015 11:50 PM
TX Tahoe Z71
Aug 7, 2015 03:58 AM
