another 80E swap?
Old Mar 7, 2011 | 12:48 PM
sharpshooter's Avatar
Default another 80E swap?
Which 60e cooler line do you re-use for the front cooler fitting on the 80e? is it the upper or lower line on the 60e that goes to the front fitting on the 80e?
thanks
Old Mar 7, 2011 | 12:58 PM
lownslo's Avatar
doesn't matter cause the trans is what pumps the fluid and it doesn't matter but I used the one that feeds the top of the radiator from the front i think. then let it drain by gravity..... maybe someone will give ya more info on this!
Old Mar 7, 2011 | 06:16 PM
I see what you mean,that it doesn't really matter.
I think my 60e pumps it through the radiator,then the cooler and then back to the trans.
I wanted to run it the same way.
Old Mar 7, 2011 | 06:33 PM
Atomic's Avatar
I have a gauge for that
The rear is the return on the 80e....you need that special rear fitting for the 80e, and it comes in a pack with a new front one.
Old Mar 7, 2011 | 06:44 PM
I know I need to extend the rear line but will the 60's lines clip into and work with the 80's fittings?
Old Mar 7, 2011 | 08:10 PM
I thought I read they do?
Old Mar 7, 2011 | 09:33 PM
shawnss's Avatar
yes they should be the same style end that the 4l60 has. there is a few different ways you could extend the rear line. i went with all new lines. i got rid of the factory lines. here the ends i went with they work great. then i went with presslock lines and AN fittings.
the one on the left is the rear fitting thats difference in the fittings
Old Mar 7, 2011 | 09:37 PM
thanks man
Old Mar 7, 2011 | 09:41 PM
GMCtrk's Avatar
60e lines attach fine. I used a 2500 suburban line for the rear fitting. The only problem is, I forgot to account for the fact that they also have a 34" radiator. I have the 28". So I had to do some serious bending on the line to get everything to work. With efans it required no mods, but with the clutch fan I had to bend it. The line cost around $30 from the dealer.
Bluecollar Hotrods
Jun 11, 2024 11:37 PM
05GMC4.8
Aug 7, 2015 09:55 PM
iregret
Jul 27, 2015 10:32 PM
alex226
Jul 16, 2015 10:55 AM
JordanH
Jul 14, 2015 03:46 PM
