alright, what's the deal with my tranny?
Old Jun 21, 2006 | 01:47 PM
  #21
moregrip's Avatar
what a rush!
thanks guys, now I am headed in a direction, hopefully it works out to be a tuning issue
Old Jun 21, 2006 | 01:59 PM
  #22
Wilde Racing's Avatar
How do I change this text
Let us know what you find. I'm having the same issue with mine. Might be time for me to dive into my 80e and see if I can't screw something up.
Old Jun 21, 2006 | 10:33 PM
  #23
moregrip's Avatar
what a rush!
will do, won't be able to get to it until the weekend though
Old Jun 22, 2006 | 08:08 AM
  #24
dewmanshu's Avatar
Moderately Differentiated
Man, I missed this thread.
I made ALL my desired shift times zero. Normal and Performance about 3-4 months ago. Took care of that adaptive learning real quick. No more soft 1-2's for me.
This adaptive learning and burst knock are 2 things in our pcm's that to me proves GM (and any other manufacturer for that matter) builds vehicles for the masses, not performance minded folks like ourselves.
Old Jun 24, 2006 | 11:46 PM
  #25
I wish that was my problem.
Old Jun 28, 2006 | 03:53 PM
  #26
LBSBLOWN's Avatar
Check your MAF readings in your logs and see if they are less at WOT then before, your MAF may be dirty which will report less airflow to the PCM and
calculate less TQ and give you a softer shift at WOT.
Also I noticed quite a bit of change in the trans shifts when I did the 90mm TB mod, just requires a bit of tuning to get it back to what I like.
Old Jul 15, 2006 | 07:20 PM
  #27
moregrip's Avatar
what a rush!
I zero'd out all my desired shift times today. The 1-2 seems slightly better but not much. I guess at this point I'll change the tranny fluid and filter and see if that helps any.
Old Jul 16, 2006 | 08:56 PM
  #28
dewmanshu's Avatar
I've read a few of your threads around grippy...hate to say, but when you don't change anything in your tune and then out of no where you start having issues...it is morehtan likely mechanical. HOWEVER, an 80e? hmmm. What converter do yu have?
Old Jul 16, 2006 | 09:06 PM
  #29
moregrip's Avatar
what a rush!
currently a stock converter, although I have a PI Vig sitting in a box in the garage as well
Old Jul 16, 2006 | 11:19 PM
  #30
moregrip's Avatar
what a rush!
so here's the deal...........are you thinking the converter is going? Every shift situation feels good except when I'm pouring on the power.......thoughts?
