Are all 4l60 the same?
Old Mar 29, 2012 | 11:16 AM
Half-bred's Avatar
Default Are all 4l60 the same?
I have a 01 silverado and I took the old 4l60 out and went with a turbo 400 behind my turbo setup but now I am going back to a stock setup I got my 4.8 but I need to find a stock 4l60. Are the plugs all the same on those trannys? Please Help
Old Mar 29, 2012 | 11:43 AM
black04's Avatar
As long as its 99-06 will be the same other than the neutral safety switch which you can swap. Not sure if the 07+ transmissions are the same.
Old Mar 29, 2012 | 11:59 AM
2007chevy5.3l's Avatar
07+ won't work on your truck
Old Mar 29, 2012 | 12:49 PM
Half-bred's Avatar
Thanks
Old Mar 29, 2012 | 07:06 PM
Vince B's Avatar
Just make sure that the pins on the main harness connector are the same as what you have. As early as 06 you could have a turbine speed sensor in these units and these will have more pins. I have swapped early and later 60E units with the two styles of EPC solenoids and have not run into an issue doing this. HTH Vince
Old Jul 19, 2012 | 02:37 PM
Half-bred's Avatar
OK one more question does the tranny need to come out of a truck or are cars different?
Silver8ado
13
Oct 21, 2024 09:09 AM
Blwn99x
Mar 24, 2023 11:14 AM
blown02408
Feb 24, 2016 04:50 AM
11MPG
Sep 8, 2015 04:52 AM
lo&sloSierra
Jul 19, 2015 10:56 AM
