Alignment problems on 02 2500 hd
Old Oct 5, 2009 | 09:45 AM
ndependent's Avatar
Registered User
Default Alignment problems on 02 2500 hd
I have a 02 2500 hd . It has the "leveling kit" lift from my knowledge. 1 1/2 blocks in the back and i believe the ford keys. It look to be about 3 inch lift. Are yall running into problems with not having enough adjusment for caster and camber? Someone told me they sell aftermarket upper a-arms that are either longer or have more adjustment? Is this true? Its a couple of degrees out on both sides camber worse that caster. Can someone point me in the right direction? thanks for any help
Old Oct 5, 2009 | 12:36 PM
AKlowriderZ71's Avatar
11 Second Hall Moniter
You won't be able to use "factory specs" after installing a lift-level kit. Use these specs instead.
Left caster 2.0 degrees
Right caster 2.5 degrees
Left camber 0 degrees
Right camber -0.25 degrees
Toe-in -1/32" or -0.087 degrees
Old Oct 5, 2009 | 12:43 PM
ndependent's Avatar
Registered User
Ok thanks a lot. And these specs will allow the tire to wear evenly? If properly rotated? thats my only real concern. As of right now it drives stright but i can tell left side the camber is out pretty good.
Old Oct 5, 2009 | 01:36 PM
Yes, and rotate your tires every 4-5000 miles. Check the alignment again in 6 months.
calsdad
Jun 14, 2023 11:07 PM
dsbodley
Nov 14, 2015 09:46 PM
lukn4trbl355
Oct 21, 2015 11:19 PM
02AWDAWSDenali
Oct 1, 2015 05:08 PM
murderedSS
Sep 27, 2015 10:16 PM
