Alignment problems on 02 2500 hd
I have a 02 2500 hd . It has the "leveling kit" lift from my knowledge. 1 1/2 blocks in the back and i believe the ford keys. It look to be about 3 inch lift. Are yall running into problems with not having enough adjusment for caster and camber? Someone told me they sell aftermarket upper a-arms that are either longer or have more adjustment? Is this true? Its a couple of degrees out on both sides camber worse that caster. Can someone point me in the right direction? thanks for any help
You won't be able to use "factory specs" after installing a lift-level kit. Use these specs instead.
Left caster 2.0 degrees
Right caster 2.5 degrees
Left camber 0 degrees
Right camber -0.25 degrees
Toe-in -1/32" or -0.087 degrees
Ok thanks a lot. And these specs will allow the tire to wear evenly? If properly rotated? thats my only real concern. As of right now it drives stright but i can tell left side the camber is out pretty good.
calsdad
Jun 14, 2023 11:07 PM
lukn4trbl355
Oct 21, 2015 11:19 PM
