air assist for the rear only
Old Apr 29, 2005 | 02:51 PM
Matt@adams's Avatar
FormerVendor
Default air assist for the rear only
Air suspension is a new area for me so I'm in need of some help.
I just installed the McGaughy's drop on my SS and I want to get some bags out back to keep the rear level if I ever put a load in the bed. Whats a good reasonably priced kit for light duty use... I don't use this truck to tow or anything so I'm thinking a small compressor should do the trick.... any help is appreciated.
Old Apr 29, 2005 | 04:02 PM
Dub Silverado's Avatar
I think there is a compnay called air extreme or something that has a air over leaf setup. If i remember its like 150 bucks? or something like that. But then you have to buy a compressor too. I would say it will cost around 400 for the load assist bags to get it complete. Check summit or stylin concepts.
Old Apr 29, 2005 | 10:26 PM
a company called air-lift makes an "air-over-leaf" kit for trucks that have been lowered. those other kits you see on ebay all the time wont work for a vehicle that has been dropped(bags are too big). i know summit racing sells them for like 175 or something like that. you can check out air-lift on the net for more info.
Old Apr 30, 2005 | 07:55 AM
Yea, look around in truckin mag you will see their add.
Old Apr 30, 2005 | 01:16 PM
Matt@adams's Avatar
FormerVendor
Thanks guys!
Old Apr 30, 2005 | 05:32 PM
Y2KSierra's Avatar
How was the rear lowered? Shackles and hangers? If so, the slam air helper bag system wasn't designed to work with these components...I believe they are designed to work with either a flip kit or a stock truck. Air Ride Technologies, Air Lift, and Firestone all make helper bags for the back that sound like what you are looking for though.
Old May 4, 2005 | 01:20 PM
blue 01's Avatar
I used Shackles and hangers to lower the back of mine 4 inchs and the slam air helper bag system works great. Perfect fit
Old May 4, 2005 | 01:46 PM
Mort's Avatar
Air Lift - Slam Air
Air Lift at Jegs
I have Air Ride Helper Bags on my 1500Hd with a McGaughys' 3/5 drop but I don't think they make stuff in general for lower vehicles. They just fit and gave me 4200 lb helper capacity. Air Ride . I got them because McGaughys' recommended them. If you call them they will tell you what they can do for you. I did not bother with a compressor just fill them by hand. They levelled out the rear of my truck side to side and I put a separate air supply to each and they act a bit like a sway bar. If you put a common air source they will wallow side to side as the weight changes and the air flows from side to side.
Worked great for me a keeps the truck from banging the axle on really sharp bumps.
I got some good info fromFullSizeChevy in the Street forum.
Old May 4, 2005 | 05:02 PM
blue 01's Avatar
They do make them for lowed trucks. I have them on my truck with the loader controller on board compressor.
http://www.airliftcompany.com/new-index/Frameset.htm
SLAM AIR BY AIR LIFT (Helper bags for lowed trucks)
Description: Slam Air; For Lowered Trucks; Rear; Lowered 2 in.- 4 in.;
Features
Up to 2000 lbs. of Leveling Capacity
Eliminates Bottoming Out
Adjustable Spring Rate
Comfortable Ride
For Variable Load Requirements
Easier And Faster Installation
Detailed Instructions Included
Two Year Limited Warranty
GXPJAY
Feb 13, 2022 08:15 AM
Corvette454l88
Sep 1, 2016 01:24 AM
DarkhorSe_SS
Aug 20, 2015 08:58 AM
shupe
Aug 5, 2015 06:45 PM
Ketis
Jul 23, 2015 12:37 PM
