Ah! 4l80e swap, 2500 HD dipstick is not working!!
Old Aug 6, 2011 | 08:27 AM
TXjeepTJ's Avatar
Default Ah! 4l80e swap, 2500 HD dipstick is not working!!
So I went to the dealer a couple weeks ago, bought a dipstick off a 2002+ 2500HD truck for my 4l60e to 4l80e
After a night of hell, I was ready to add transmission fluid so I go to install the dipstick and it isn't working out at all. I then compared it to my 4l60e dipstick and it was exactly the same
what do you guys think?
Old Aug 6, 2011 | 08:31 AM
charcold-bowtie's Avatar
whats the PN of it? If its the same as the 60, then obvsly its not the 80e stick. As well as, those are a bitch to put in if you do it after installing the tranny.
Old Aug 6, 2011 | 02:37 PM
TXjeepTJ's Avatar
Yup, it was the wrong part they gave me, I got the new one and it looks totally different from the 60e dipstick. Hopefully I will get lucky and get it in in a timely manner!
Old Aug 6, 2011 | 03:15 PM
TIM Z's Avatar
11 sec. Truck Mod
You need one from a 2500HD avalanche or suburban.
Old Aug 6, 2011 | 03:57 PM
GMCtrk's Avatar
the truck one works fine for me
Old Aug 6, 2011 | 04:51 PM
AKlowriderZ71's Avatar
11 Second Hall Moniter
If you've already installed the transmission, and now you're trying to put the tube in, it's gonna be a huge PITA. The trick is to get the tube "situated" while you're stabbing the transmission.
Old Aug 6, 2011 | 04:53 PM
If that's the case, remove the coil pack & right side valve cover to get some extra room. You may also need to raise/lower the rear of the transmission for some additional room to get that thing in there. Good luck!
Old Aug 6, 2011 | 05:40 PM
Camaro Zach's Avatar
no need to remove the coils or anything else. Just stab it to the right a bit of where it is supposed to end up and rotate counter-clockwise as it goes down.
This has never failed me and I always use Truck dipstick tubes.
Old Aug 7, 2011 | 12:25 AM
TXjeepTJ's Avatar
Thanks for the help guys, I got lucky (I guess I did exactly what camaro zach did, I just didn't know what I was doing, just twisting/pushing) and nailed it after about the 3rd try
Old Aug 7, 2011 | 12:29 AM
Excellent!
