Aftermarket transmission cooler mount location
Old Mar 6, 2013 | 09:13 AM
AndysC3's Avatar
Mine is done the same way smokeshow did his. And I also bypassed the radiator. It's just to help with heating the trans fluid on cold starts.
Old Mar 6, 2013 | 05:48 PM
Beatdown Z's Avatar
Laid Back
Smokeshow and AndysC3, what temps do your transmissions run at with the cooler mounted low?
Old Mar 7, 2013 | 09:32 PM
AndysC3's Avatar
Crushing around town I see 130-140 with 75-80* outside temps. This is with an 80e and a 3200 stall. It got to about 175 after several back to back wot pulls
Old Mar 8, 2013 | 05:37 PM
Beatdown Z's Avatar
Laid Back
What about doing one WOT pull? My temps will jump up at least 10 degrees after a little WOT hit. Trans doesn't feel like it's slipping. I'm running a Trans-Go HD2 in a stock 60k mile trans.
Old Mar 8, 2013 | 07:00 PM
smokeshow's Avatar
Mod with training wheels
Driving normally my trans temps were only about 30° above ambient. After a single pull they might be 60-70° above. I've always watched temps, and without a fan on the cooler, I can do 3 back to back full boost runs without letting it cool down. After that I have to drive around for maybe 10 minutes to let it cool off. All that info is assuming between 800-850 at the wheels. My estimate for pulling on a 680whp cobra, anyway
Old Mar 8, 2013 | 07:49 PM
ak2007r6's Avatar
It doesn't. You can bypass the radiator if you would like.
+1 Mine bypasses the radiator also with no problems. Live in Alaska and maybe miles driving in below freezing temps. Just let it warm up a little and don't go romping on it till it's warmed up and gone through the gears some.
Normal driving I see around 100, little cooler on really cold days. Summer it's 110-115
zblee
63
Jun 10, 2023 01:25 PM
5.3Okasai
Mar 9, 2022 01:07 PM
thewrx
Aug 12, 2015 08:28 PM
Ammadien
Jul 22, 2015 08:50 PM
