aftermarket rotors
Old Feb 7, 2009 | 11:54 AM
006rcsb's Avatar
Default aftermarket rotors
why is it so hard to find aftermarket rotors for my 06, i find websites that list 99-06 which i know is bs because they went to a larger diameter front rotor after they switched back to rear drums (hence the reason they had to go to a 17 inch rim). I find over sized rotor kits that come with caliper relocators that say for 99-06 and im not sure that they would work either... can someone help me out
Old Feb 7, 2009 | 01:07 PM
MADS99's Avatar
SSBC Web Site I Found these part # The front A126-56 and on the Rear part #A126-48,they are both 3 piston Calibers.They are for a 2006 Chevy Silverado 4x4 And just need to be min 16 ins rims.Hope this helps,Later
Old Feb 7, 2009 | 01:26 PM
006rcsb's Avatar
yeah not looking to spend 2600 dollars on brakes, just lookin for a nice set of slotted rotors, the problem is that i keep finding rotors listed as for an 06 but they state that they are only a 12 diameter rotor. the stock rotors are a 13 inch diameter rotor.
Old Feb 7, 2009 | 01:30 PM
D_reks{5.3}'s Avatar
im in your same boat..not looking to spend a fortune, just some slotted rotors for better look and a little better stopping power over stock. I found some on ebay that are pretty cheap. I posted a thread on here last night if you wanna check them out. Also powerslot is a known brand and they have them for like $120 per side. And i think they are 14".
Old Feb 7, 2009 | 01:40 PM
006rcsb's Avatar
woo hoo a fellow bakersfieldian! are they the over size ones with a caliper relocator and all? post up some of those part numbers if you got them handy.
Old Feb 7, 2009 | 01:43 PM
MADS99's Avatar
Got ya,you are just looking for rotors.
Old Feb 7, 2009 | 01:59 PM
006rcsb's Avatar
ok, i did some digging and found part numbers for some of the power slot rotors, they are Power Slot 8657PSL and Power Slot 8657PSR and are the 13 inch diameter rotors buybrakes . com even lists them as for models with rear drums. and they are about 120 a piece. thanks d reks!
Old Feb 7, 2009 | 02:04 PM
anytime man..speedeng also sells them..so where at in bako do you live?
Old Feb 7, 2009 | 04:15 PM
006rcsb's Avatar
off of wible rd south of panama ln, how bout you?
Old Feb 7, 2009 | 06:04 PM
In the dale..
