after new gear install few small problems
Old Oct 29, 2011 | 01:00 PM
lukn4trbl355's Avatar
Default after new gear install few small problems
hey guys, so last night me n my buddy regeared my front diff, put all new bearings, races and seals in and the new 488 gearset...last night after putting it in and getting her back on the road i realized two things...one my truck gets MAD death wobble between 40-50, so im gonna go over everything and see if any bolts loosened up. and now after having no 4wd for 3mo(and the actuator still worked) now it wont...checked the fuse for 4wd, thats good, checked the actuator with acc mode on and the actuator would not expand outwards or even make a click. so my guess is its either the actuator or the actuator harness? i was also just wondering if it is possible that something couldve gotten fucked up that wont allow the diff to engage, also the t-case will engage but not the diff. in order to pull the diff i did have to disconnect my gearbox and the pass side axle tube, im almost 100% positive that the axle tube assy with the clutch fork looking deal and the spring are in the correct way if anyone could help me out itd be greatley appreciated! specially with winter coming up real soon!
thanks
tj
Old Oct 29, 2011 | 05:10 PM
ohmed everything out, from main harness put out 14.5v while truck was running, then ohmed the actuator harness and it also put out 14.5v, put new actuator in still didnt work and still no 4wd light...
Old Oct 30, 2011 | 12:20 PM
nobody has any idea??
Old Oct 31, 2011 | 01:01 PM
well never felt more like an idiot in my entire life, the one pin in the actuator harness for the power out...**** was so corroded couldnt even see the pin, cleaned it in coke and picked the loose corrosion off, used an elec. cleaner n dialectric grease n now she works perfectly
ferrellrooster
Mar 6, 2025 03:22 PM
LCHEE
Oct 24, 2020 04:10 PM
iregret
Jul 27, 2015 10:31 PM
lxcoupe
Jul 21, 2015 02:12 AM
lxcoupe
Jul 14, 2015 10:14 PM
