Accum piston spring
Old May 25, 2007 | 12:50 PM
jadaven's Avatar
Default Accum piston spring
Anyone have any experiance with this? Should I get one? To go with my HD2?
When I get it.
Spring??
Old May 25, 2007 | 03:40 PM
bgray's Avatar
TOTM: June 2007
my hd2 and sonnax 2nd gear servo chirps second.....so id say it doenst neeed a spring to be any firmer...
Old May 25, 2007 | 05:13 PM
jadaven's Avatar
Think it will do well behind a 4.8?
Old May 25, 2007 | 07:20 PM
FLT's Avatar
FLT
FormerVendor
With the HD-2 kit you will not need any accumulator springs. We get calls all the time about harsh 1-2 shifts when guy's buy kits from our competitors. Keep in mind that you will not get any technical assistance when you purchase a kit from them. It might be cheaper than ours but when you have a problem your pretty much on your own or you will need to call trans-go. Good luck. Vince
Old May 25, 2007 | 09:52 PM
bgray's Avatar
TOTM: June 2007
I can 100%vouch for FLT. They are the best guys to dela with. I had such a little problem, it was correct in FULL LENGTH and i couldnt be any happier with there service.
dont be cheap..go FLT
Old May 26, 2007 | 08:37 AM
jadaven's Avatar
I've always heard good things about FLT. silver-mod-o's trans looked awesome, the first and second time i saw it.
Old May 26, 2007 | 08:51 AM
95ImpSS's Avatar
formerly 1BADC10 (12/14/2011)
Um... if my memory is correct, doesn't the HD2 come with the recommended hardware from Transgo? I'll have to go and look at the instructions, but I didn't buy anything outside of what came with that. One thing you'll want to remember is DO NOT INSTALL MORE THAN ONE WASHER! ...at least not for a DD. Shifts are way too firm for DD use.
Old May 27, 2007 | 12:02 AM
agreif's Avatar
Man, this guys knows his stuff doesn't he!?! Exactly what he said. If you keep your 1-2 accum set up same as stock with the aluminum piston your shifts will be very tolerable around town and still firm when you get into it.
Old Jul 11, 2007 | 03:40 AM
cpelton's Avatar
sorry about digging up an old thread but I just installed a the hd-2 kit in a my new tranny which I have not put in the truck yet. I set it up according to the instructions but i did not use ANY washers, how would you think this will shift? It went together quite different from how I pulled it apart, the piston is flipped over and there is now springs in each side of it - according to the transgo instructions. Should I put one washer in? Truck is a daily driver and i dont want it to shift overly aggressive. I also have a 2500 stall which will be going in with this tranny.
natejk
Nov 15, 2016 08:05 AM
jtphelps289
Sep 29, 2015 12:00 PM
11MPG
Sep 10, 2015 08:34 PM
bisqikss
Sep 8, 2015 03:35 AM
LT-1 SS
Sep 3, 2015 10:24 AM
