ABS Light When i Launch From A DIG ???
Old Jul 6, 2010 | 12:17 AM
m3srt's Avatar
Banned
Default ABS Light When i Launch From A DIG ???
i recentley installed a circle D 3,200 single disc ... well i diddnt install it myself but anyways ... ever since the stall was put in ,, i launch from a dig and the abs light comes on ... if i hit the brakes hard the tires lock up nasty ... i turn the truck off and leave it sit for a few mins and it goes away but EVERYTIME i launch the abs light turns on .. wtf is going on here ???
Old Jul 6, 2010 | 01:12 AM
Bumpers's Avatar
Do you brake stall it and launch? Or just flash the converter? A lot of times when the abs lights kick on it can be a hub assembly.. Jack it up and see if there any slack or noise or anything coming from either side. If not I would just check the sensors and wiring and after that I don't know what to tell ya
Old Jul 6, 2010 | 02:08 AM
m3srt's Avatar
Banned
eitehr way i take off hard it turns on teh light on
o btw i have no traction control at all
Old Jul 6, 2010 | 11:50 AM
budhayes3's Avatar
PT's Slowest Truck
Got any codes? That will give you a hint of what's going on...maybe the tires are spinning in the rear and giving the ABS module a different speed signal than the front?
Old Jul 6, 2010 | 12:45 PM
MPFD's Avatar
11 Second Truck Club
Don't your style of truck have 4 wheel ABS with tone rings on each corner? I'd be willing to bet your getting the tires spinning at different speeds and your abs light is coming on to indicate that there is an erratic speed change...
My ABS light comes on sometimes in the water box, but it always goes back off after I restart the truck and drive it a few feet.
Old Jul 8, 2010 | 12:02 AM
iamkeniff's Avatar
i never had this problem. i havr a traction light from a dig and any mph up to 50. but then again its because the tires are spinning. i have no idea about the abs light. im running the same converter as you.
carid
Oct 28, 2015 08:24 AM
drummer0415
11
Oct 24, 2015 08:16 PM
Lthompson
Sep 21, 2015 07:06 PM
TAPyvehc93
Sep 12, 2015 08:19 PM
03chevytruck
Sep 10, 2015 10:18 PM
