ABS and BRAKE! light stays on
Old Jul 24, 2006 | 05:03 PM
9GMC9's Avatar
Default ABS and BRAKE! light stays on
I just came back from vacation and while I was over there I noticed that sometimes when I turn my truck on the ABS and BRAKE! light on the dash stays on. Later on I found out that my rear diff slipped because of a broken leaf spring bolt, fixed that and the ABS lights still stays on sometimes. What could this be???
Thanks
Old Jul 24, 2006 | 05:15 PM
gmtechnician's Avatar
you need to find out what code your abs module is setting. it could be a hundred things. start with finding out the code.
Old Jul 24, 2006 | 05:17 PM
RoninsDenali's Avatar
Get someone to scan your DTC codes, alot of info can be gathered just from one code from the EBCM module.
Like for me, just today i got a 'Service Stability' message, apparently my steering wheel position sensor is acting up. 3 codes, all pointed to that sensor.
TurboBerserker's Avatar
I AM A MOTHERF*CKER
Check your front bearings.
Corvette454l88
Sep 1, 2016 01:24 AM
08lambochevy
Aug 14, 2015 07:50 PM
97aztecgt
Aug 13, 2015 02:11 PM
atxlt
Jul 20, 2015 11:06 PM
Offroadunleashed
Jul 20, 2015 02:25 PM
