About to torch it...
Old Aug 13, 2013 | 10:28 AM
DrX's Avatar
DrX
Exhaust crossover under the rear of the pan shouldn't make any difference cruising down the highway. I didn't find anything with the temp gun other than cooler on the bottom of the pan and 2XX* on the sides when I was logging 2XX*.
Old Aug 13, 2013 | 10:35 AM
03sierraslt's Avatar
Ya, exhaust isn't causing your issue unless return line is on it.
Old Aug 13, 2013 | 10:56 AM
jschrock's Avatar
Well, I feel like a tard...
Trans temps by gun:
Converter:
180 by flywheel to 195 near front pump
Trans pan: 130-160* 160 being close to the exhaust
Lines:
Supply to cooler: 116*
Return after cooler: 109*
Trans temp was reading 205*
As soon as the rain lets up I will do some more testing, but looks like I will be dropping the pan to replace the sensor.
EDIT: Temp gauge got hotter and temps were higher so may not me the problem.... Can't remember all temp numbers highest was 240 on TC
Old Aug 13, 2013 | 01:05 PM
Are those running temps or engine off?
Old Aug 13, 2013 | 02:34 PM
cdub81's Avatar
Trans temps by gun:
Converter:
Lines:
Had the same issue with the 4l80 I swapped in. Same exact temp readings at the 40k in and out. At first I thought I had found the issue with dirtdobbers building a nest in my new 80e lines but that wasn't it. Temp would climb slowly, If I kept it at 60mph it would hover about 220... With a 90 deg ambient temp. Make a 2 month long story short, there was a crack in the center support and the pump was replaced completely from another unit. So I'm really not sure which was the culprit but it works flawless now. Gilbert @ Ace def had his work cutout on this 80e build!
Old Aug 13, 2013 | 03:24 PM
jschrock's Avatar
Engine running
I hope that is not the case, I got a temp sensor I can swap in and hope like hell it fixes it. What year of trans did you have with the center support crack?
Old Aug 13, 2013 | 04:20 PM
cdub81's Avatar
Engine running
It as a 2001 model
Old Aug 13, 2013 | 09:31 PM
jschrock's Avatar
What is acceptable for converter slip? (RPMs)?
Old Aug 14, 2013 | 10:29 AM
DrX's Avatar
DrX
0 when locked. Unlocked it is going to depend on engine RPM, torque, stall speed, etc. More slip when unlocked = more heat.
Old Aug 14, 2013 | 11:18 AM
jschrock's Avatar
I'm seeing 120rpms at 50mph, 150 at 60, and 175 at 70
