about to install a shift kit
Old Aug 4, 2009 | 03:26 AM
brandon_6667's Avatar
Default about to install a shift kit
I bought a shiftkit and a few other items about a year ago and am finally going to get around to installing it. The truck is a 2000 silverado 5.3L with the 4L60e tranny
below is the list of parts I bought, Im just wondering if I forgot anything, anyone have any suggestions of anything else that would be good to replace while in there?
Transgo HD2 shift kit
Transgo Seperator plate
Corvette servo
1-2 aluminum accumulator piston (small pin)
Foward clutch aluminum accumulator piston
so, anything else worth replacing while im at it??
Old Aug 4, 2009 | 09:48 AM
Dezert1500's Avatar
fwd, 1-2, and 3-4 accumulator pison orings. ATP trans filter (best gasket). Run regular md3 atf.
Old Aug 4, 2009 | 10:44 AM
jiar577's Avatar
Get the 3-4 accum piston. It's the same as the 1-2 accumulator, just used in a different part of the tranny.
You're set.
Old Aug 4, 2009 | 10:49 AM
Dezert1500's Avatar
Why get the 3-4 when it's already aluminum?
Old Aug 4, 2009 | 11:18 AM
SILVERBIRCH's Avatar
how much $ is this running you parts and labor ive been wanting to do the same to mine.
Old Aug 4, 2009 | 12:52 PM
I dont have the invoice on me, but the parts I listed was around $135.00 total from oregonperformancetransmission.com
Old Aug 4, 2009 | 12:57 PM
jiar577's Avatar
On my '06 it was plastic; it should be the same on older models.
Old Aug 5, 2009 | 01:46 AM
05GMCL33's Avatar
When installing the HD2 do NOT install any spacers in the 2ed gear accumulator.
Old Aug 5, 2009 | 03:30 AM
black04's Avatar
My 3-4 piston was aluminum in my 04. I would get a new oem pan gasket unless you get an atp filter with a new one. The transgo cork gasket is junk.
Old Aug 5, 2009 | 09:50 AM
jiar577's Avatar
Interesting, I guess GM screwed me lol
Brandon, if you drill the plate to the size in the instructions you'll get harsh shifts as this kit was designed for F bodys and the trucks are different. I did a lot of research before installing my HD2 and most people liked this for a DD:
1-2: don't drill at all
2-3: use a .093 drill
3-4: use a .110 drill
I installed mine with those specs and it shifts a bit firmer (compared to stock) at partial throttle, but at WOT you get fast & firm shifts without banging, the best of both worlds IMO. I don't think you'll want firmer shifts for a DD honestly.
