99 GMC Sierra 4l60e removal, need some help!
Old May 24, 2016 | 03:01 PM
  #41
Wolftrk99's Avatar
Its not too bad 22mm wrench abd you can get it, unless youve got headers that put it in a goofy spot
Old May 25, 2016 | 01:34 PM
  #42
slonlow2000's Avatar
No I was talking about the plug in for it. Its up above on the fuel rails. I got it in last night. Should be able to get it finished tonight. I forgot how the trans dip stick was routed so I had to look at a guys truck here at work today.
I did break this way back when I was pulling the trans though.
1999 GMC Sierra by Gabe Reed, on Flickr
What the heck is it called and where can I get one?
Old May 25, 2016 | 02:00 PM
  #43
tgui's Avatar
Neutral safety switch.
Next time use a heat gun to loosen up the crap GM puts in that connector.
Amazon.com: ACDelco D2263C GM Original Equipment Park/Neutral Position and Back-Up Lamp Switch: Appstore for Android Amazon.com: ACDelco D2263C GM Original Equipment Park/Neutral Position and Back-Up Lamp Switch: Appstore for Android
Old May 25, 2016 | 03:07 PM
  #44
I shoved a pocket screw driver into my thumb and after that point I was done with that damn thing. Didn't even think of heat working. That crap was like glue.
Old May 25, 2016 | 11:02 PM
  #45
Wolftrk99's Avatar
Pocket screwdriver through the thumb will make you do a lot of things... Lol!!! They put dieelctric grease of some sort in there, but with the heat from exhaust and trans it hardens...
Old May 25, 2016 | 11:22 PM
  #46
1FastBrick's Avatar
Custm2500's Rude Friend
Its some kind of sealant glue, Not dielectric grease.
I warm it up with a pocket torch and it melts enough to remove the connector. but starts to harden back up when it dries again.
Old May 25, 2016 | 11:47 PM
  #47
Wolftrk99's Avatar
Do replacements come with same crap in them or is it just the oe units??? Either way its a PITA!!!
Old May 25, 2016 | 11:50 PM
  #48
1FastBrick's Avatar
Never had to replace one. I suspect it's only off the assembly line.
Old May 25, 2016 | 11:52 PM
  #49
Wolftrk99's Avatar
Ive found its mostly the lower connector that is the bigger pain of the two.... Have been able to get the lower out withiut too much hassle on a regular basis, but that upper one is a ****!!!
Old May 26, 2016 | 06:45 AM
  #50
tgui's Avatar
Exactly. Uhhhgg. Heat, pry a little, heat, pry a little cuss, stab hand, cuss more....
I ended up getting a spare NSS just in case because of the horror stories.
