99 GMC Sierra 4l60e removal, need some help!
Old May 17, 2016 | 09:13 AM
  #31
Wolftrk99's Avatar
They sell an aerosol trans flush, parts store may have it or the trans shop may be able to get you a can...
Old May 20, 2016 | 02:42 PM
  #32
slonlow2000's Avatar
They shop gave me a can of the flush. Does is matter which line I run it into?
Also what fluid do I need to run in this, its a 99 4l60e?
Old May 20, 2016 | 02:46 PM
  #33
Wolftrk99's Avatar
Dex 3 would be optimal.... 6 will work, but gm calls for 3
Old May 20, 2016 | 02:47 PM
  #34
Wolftrk99's Avatar
Run it through both lines, flush and backflush!!!
Old May 20, 2016 | 05:24 PM
  #35
I'm guessing the way you out it that dex 3 is hard to find?
Old May 20, 2016 | 06:01 PM
  #36
tgui's Avatar
Dex 6 is at least as good as dex 3. Walmart has a ton of dex 6 so that's what I run
Old May 20, 2016 | 06:03 PM
  #37
tgui's Avatar
If I was worried about **** in lines and the cooler I'd get all new stuff. So that's what I did.
Look at the true cool 40k sticky!
Old May 20, 2016 | 07:19 PM
  #38
Wolftrk99's Avatar
Dex 3 is available... But it has been superceded by dex 6..... Im running 6 because the dealership i work for doesnt have 3
Old May 20, 2016 | 07:20 PM
  #39
Wolftrk99's Avatar
Even new coolers should be flushed.... Nothing worse than a piece of styrofoam stuck in a cooler!!!
Old May 24, 2016 | 12:19 PM
  #40
I got it all flushed out good, followed the can flush with some air. Now I got to finish connecting everything. Had to wait on the o2 sensors from the dealer. That driver side wouldn't be fun once the trans was back to the original position.
