99-07 4WD Front Coilover Conversion
Old Apr 15, 2016 | 06:34 AM
  #231
mikeyjm1's Avatar
Yes they all fit.
Old Apr 29, 2016 | 09:46 AM
  #232
Rompn's Avatar
Originally Posted by WeDgE1
Yes, DS303 with 1100lb springs.
Ride height measured from middle of top and bottom bolts. Upgraded bearings used.
Shakes the truck as in it felt like the shock/spring was replace with a solid piece of metal. Just very very harsh with the 22s. This was with the shock setting at 12-15.
6 seems to be perfect as it doesn't bounce and it's not *too* stiff most of the time.
How much longer of a shock could I use if I went with the stud top mount? I'd like to run a shock that would allow me a 800-900lb spring, and I'm pretty sure I'd have to run the DS501 for that...
Same here on Factory 20's. 05' extended cab...
I avoid anything that looks like a bump in the road because it shakes the hell out of the truck. I'm on a DS301 setup with a 1300lb spring. I feel it is way to stiff. Thinking of coming down to at least 1100lb, possibly more. Looking for some sort of formula to follow though.
Same shock settings here too. Somewhere around 5-6 in the front and two clicks more in the rear. I've tried numerous combos of settings and around this is the best, which sucks, with the 1300lb spring.
I'm also looking at going back up to stock height, so a DS303 setup, if I remember right, to increase some shock travel some. Not looking forward to eating the hundreds of dollars in cost again to do so however.
Also, anybody using this kit having issues with their turning radius? I definitely lost a bunch after the swap and have had the truck laser aligned twice now thinking it was that.
Old Apr 29, 2016 | 10:34 AM
  #233
Atomic's Avatar
I have a gauge for that
From what I have seen, any time that someone says the ride sucks or it shakes it means the shock is not set up properly in the middle of its travel or the bumpstop is not installed. I have a feeling yours is too low based on what you described, I bet if you raised it up an inch with more preload you would be much happier with it. The other option is to use the stud top and a longer shock, although you could try to the stud top right now and see what you think.
Just by itself the stud top will drop the front end 1.5" (0.75" at the shock) with no other changes. You can use the spreadsheet I posted to figure out exactly what spring and shock combo would be for a given ride height, but again it is very important to set the shock up in the middle of its travel and make sure the bump stop is installed regardless of what ride height that it.
So a couple questions,
1.) do you have the bumpstop installed properly?
2.) Are you looking to raise the height back up some?
3.) Is your shock in the middle or slightly above its median ride height?
If 1 and 2 are yes then add some preload to the spring to raise it so its higher. I know on mine with the same setup there is 3-4 threads showing below the jam nut and I have none of the issues you are describing. The PDF in the first post talks at length on how to properly set up the shock/spring and bumpstop.
Old Apr 29, 2016 | 02:58 PM
  #234
Rompn's Avatar
Hey Richard, yes to all questions and I followed your instructions to a "T". I really feel its the spring rate. I know when we spoke we figured this would be a somewhat "stiffer" ride for towing, etc., however it feels as if I'm riding in a 12" all leaf spring lifted truck on 28" tall tires.
Any thought on the lost turning radius? I have to take a different route to work now because the truck won't make a hairpin turn on the route I usually take.
Also, when I did the conversion I also ordered QA1's replacement shocks for the rear. Seemed to help out quite a bit however I noticed what appears to be fluid already leaking out of one. Not real happy so far with QA1's quality for the money.
Old Apr 30, 2016 | 07:13 PM
  #235
WeDgE1's Avatar
Richard, my apologies for taking so long to get back to this thread. I'll post pictures in the next few days of the setup. I'm positive everything is set-up correctly.
Are the bushings available from you for the stud mount tops? I'd like to explore that option before going with a longer shock.
Old Apr 30, 2016 | 10:42 PM
  #236
Atomic's Avatar
I am really not sure what to say then if everything is installed correctly, do you mind sending me some pictures just to make sure? I usually keep my shocks around 10-12 for daily driving if maybe that helps you some.
Not sure what to say about the turning radius, I havent heard that one before. Do you have drop spindles? Those generally impact the turning radius.
Yes I have some of the big washers and bushings for the stud mount. Before that though, lets make sure your current setup is all done correctly and theres not something obvious we are missing.
Old May 25, 2016 | 08:36 PM
  #237
mikeyjm1's Avatar
I may have missed it but, is anyone using aftermarket upper control arms with coilovers?
My upper control arm bushings are trashed and I'm considering trying a set of complete arms. Better ball joint angles, new ball joints, new bushings...ect.
Old May 25, 2016 | 10:30 PM
  #238
Atomic's Avatar
I know some of the lifted guys have used cognito arms with success.
Old May 26, 2016 | 05:10 AM
  #239
mikeyjm1's Avatar
Yeah being lowered, I'm thinking Ridetech or DJM. The DJMs are more economical but I worry about spring clearance. The Ridetechs look perfect but damn they're expensive. Any others out there?
Old May 26, 2016 | 10:13 AM
  #240
1bad2k's Avatar
Maybe try Moog problem solver series and run them flipped....? I think I paid like 100 shipped for the pair from summit. They have the offset bushings already installed.
