9.5" 14 bolt fitment?
Old Mar 1, 2010 | 08:53 PM
MustangPunk's Avatar
Default 9.5" 14 bolt fitment?
I think I found a 9.5" 14 bolt. I have a 2000 ECSB, the rear I found is said to be out of a newer 1500 (2006 I think?) crew cab it's a hybird axle (AXN).. I'm just making sure it'll bolt in, and my disc brakes will swap over somewhat easy?? Thanks, Matt
Old Mar 1, 2010 | 09:36 PM
bohr898's Avatar
Restricted User
if its a 99+ rear then its a direct swap...
Old Mar 1, 2010 | 10:10 PM
supersub's Avatar
AXN is the one to look for, it should bolt right up, a drive shaft end will need to be made to fit a 1350 U-joint.
Old Mar 1, 2010 | 10:12 PM
Bo185's Avatar
It should have disks already if its out of a GMT800 truck. They all had disk's even after the rest went drums in 05.
Old Mar 5, 2010 | 10:04 PM
Well the salvage yard called me back up, and when they had it checked out, a spring perch was jacked, and a axle tube was also bent up, so that's a no go.. Do the NNBS 9.5" AXN 14 bolts directly swap in too?, asumming I use the right u-joint of cousre.. Thanks guys
Old Mar 6, 2010 | 12:24 AM
BadAssChevy327's Avatar
not true. my 05 ss has this rear end and its drum. which nothing wrong with that fits 15 inch rims and stops good lol
natejk
Nov 15, 2016 08:05 AM
Justin87gn
Sep 10, 2015 12:06 PM
2004gibbstruck
Sep 7, 2015 06:05 PM
iregret
Sep 7, 2015 01:20 PM
Cowboy Tom
Sep 5, 2015 04:29 PM
