80e swap, circle d 3200 stall and 2 pc drveshaft swap
Old Apr 25, 2015 | 10:17 PM
Jetn3's Avatar
Default 80e swap, circle d 3200 stall and 2 pc drveshaft swap
I just finished my 3200 stalled Jakes 80e swap. I also added a stock 2 pc driveshaft on my 05 crew cab. I've never driven a stalled vehicle before and it takes some getting used to. I'm really liking the 80e way better than the 60e, however, the jakes stage 3 1-2 upshift is way too harsh for daily driving even with the stall. Gonna get it worked out in the tune.
One thing though, I have these bad vibrations on low speed (30 mph) decel. I though it was my 2 pc shaft and u joints out of whack, but because of the stall I think what I'm feeling is my cam (220/220 112) making my truck shake. Lol! Anyone else experience this on a cammed and stalled truck?
All in all I'm very pleased with this 80e swap
Old Apr 26, 2015 | 11:07 AM
Atomic's Avatar
I have a gauge for that
You sure its not your brakes or converter chatter?
Old Apr 26, 2015 | 12:02 PM
Jetn3's Avatar
I know they are not my brakes because I never touched them during the install. Not sure about the converter though. How can I tell its the converter and what would cause that?
Old Apr 26, 2015 | 12:44 PM
Atomic's Avatar
If you have hptuners, scan for the converter lockup PID and see if it says on or engaged when you hear it.
Old Apr 27, 2015 | 11:36 AM
Jetn3's Avatar
Thanks Atomic, I'll try it out this week. Been so busy with work, I wish I more time to work on and drive my truck.
Old Apr 27, 2015 | 12:14 PM
Atomic's Avatar
Dont we all
Old Apr 27, 2015 | 01:13 PM
GMCtrk's Avatar
No it's not your cam causing the vibration.
You modified your driveline.
Old Apr 27, 2015 | 08:06 PM
Circle-D's Avatar
Former Vendor
Yes, see what the TCC is doing - that will tell us a lot. What are the RPMs when the shudder occurs?
Chris
Old Apr 28, 2015 | 12:58 PM
SlowDude's Avatar
Did you balance the driveshafts? and or look at the flexplate to make sure there are no cracks? This will go a long way in keeping the vibrations down.
Old Apr 29, 2015 | 12:47 AM
Jetn3's Avatar
Ok guys, here's an update. I did some hp tuners logging, but I honestly don't know what I'm looking for as far as trans stuff. Flex plate is a new Circle D/Reactor flex plate, so I'm pretty sure I can rule that out. I bought a digital angle finder and what I found was my trans and the reared are 8* off. I can space up my trans and then it becomes 4* off and the shudder is not as bad and bearable.
What would you guys do, get a 8* shim for the reared or leave the trans spaced up and a 4* shim for rearend? Both ways I'd still need to adjust carrier bearing higher.
