80E swap
#21
Fastest D1 Procharged Truck
looks like thats my plan ill buy that rebuild kit from PBA and find someone in my area that
knows there **** and have at it
also im gonna do the same converter i had a yank SS3600 i talked to dave and thats what he recommended that i run what a coincidence lol
#25
#26
Damn thats a loose converter!!
With the procharger in your truck I don't see a need to go that loose... i mean sure they like a loose converter, but you only need it to be loose enough to hit decent boost off the line. Beyond that I think it will be wasted. If you don't have the power to cut a 1.5x 60' with that converter I'll eat my hat. The 3600 will have small enough shift extensions, and the 80e has tighter ratio gearing.
I have a different mind set though... I don't like loose converters which is exactly why I went down the path that I did with the maggie.
I think Idahoblkss was cutting 1.9 60' in his SSS with a cam only LQ9, a stock pulley on his D1 and a 3200 converter (which he claims is tighter than that). Granted he was running a smaller cam, but I think between all your other mods, 400 higher stall, and the reduced weight, your truck will rocket off the line.
https://www.performancetrucks.net/fo...%40119-491183/
https://www.performancetrucks.net/fo...new-pb-509695/
05GMC4.8
Aug 7, 2015 09:55 PM
iregret
Jul 27, 2015 10:32 PM
