80E Flat Flexplate
Old Apr 6, 2006 | 03:35 PM
desTRUCKtive's Avatar
Default 80E Flat Flexplate
Ok here is the problem I have a 6.0 with a 80E combo which came out of a 2000 silverado, and a PI 3200 Converter. I have the flexplate that is flat. It looks more like the old LT1 styles. I measured the bolt pattern and what the stock uses is the 11.5 pattern. I sheered one of the bolts that is on the 11.5 inch pattern... so I am running on two bolts. The converter does also have the 10.75 pattern, but my flywheel does not.
So the question is can I find a flexplate that is flat (not the LS1 with the 11 inch pattern) has the 10.75 pattern and will bolt to my crank.
I did find one but it does not bolt to my LS1 crank.
Old Apr 6, 2006 | 10:58 PM
HMM I am wondering if this might work, anyone have any ideas...
https://www.performancetrucks.net/fo...r+bolt+pattern
Post 22 from XLR8NSS
Old Apr 7, 2006 | 01:09 AM
I am really thinking that this SBC plate might work , anyone know where to get them, and do you have a part number. Also I am thinking the TCi might work but I am not to sure. XLR mentioned it being flat but having the deminsions similar to that of the bent plate.
Skip Fix
22
Jul 9, 2016 07:08 PM
lukn4trbl355
Oct 21, 2015 11:19 PM
Wrecker 426
Sep 30, 2015 09:39 PM
mitchellmade
Sep 27, 2015 08:27 PM
69z-28
Sep 21, 2015 07:31 AM
