8 lug to 6 lug
Been searching without much luck. Can I take an 8 lug semi float rear out of an hd truck and swap in aftermarket 6 lug axles? Found a couple good deals on 8 lug semi float nbs rears but need 6 lug for my truck.
You don't even need special axles.
The Brakes will be an issue though...
Yeah I'm not worried about the brakes. I read up on that part. Just couldn't find anyone that swapped axles. Was looking at aftermarket ones from summit. For the couple hundred bucks they cost I can be into a semi float 14 bolt that bolts right in for half of an ss or max 14 bolt
Absolutely! I just ordered some from summit.
Stock replacement and slightly better just below.
I went with the slightly better for $13 more an axle.
http://www.summitracing.com/parts/mgr-15521928
http://www.summitracing.com/parts/mgr-mg27106
I used a light duty 2500 14 bolt 9.5 Semi float axle from a GMT 800 Silverado in Evil GMC's axle build. The also came in 1500HD model trucks.
https://www.performancetrucks.net/fo...thread-467473/
So is the part number you gave for the 88-98 rear?
I'm looking to convert a 2001 8 lug semi float rear to 6 lug
Or am I confusing myself here lol?
https://www.performancetrucks.net/fo...ctures-477641/
I only found 1 company that would make custom axles for that rear end and they want around $800-$1000.
