700R4 to TH350 Swap
Old Oct 9, 2007 | 08:26 AM
BadBowtie89's Avatar
Default 700R4 to TH350 Swap
ok i have been looking into this swap for a while but need some feedback on what else i should do... i have a 700R4 but i friend who i trust alot. said that if you get a TH350 and put an overdrive kit on it, it'll be bullet proof.. <-- i like the sound of that... now is there anything else i should do to it? Shift Kit? etc? i already planned on putting a tranny cooler on it
Old Oct 9, 2007 | 09:04 AM
performabuilt's Avatar
LS1TECH & Trucks Sponsor
The 350 is not significantly stronger than the 700R4 and the overdrive kit is called a gear vendors unit and they run I think around 3000 dollars. I would think that swap over carefully and either go with a built 700r4 or maybe even a 4l80e.
Old Oct 9, 2007 | 09:49 AM
Dock Rocker's Avatar
If you are going with a 3 speed then a th400 is the way to go. Much stronger than the th350. I am thinking about this swap right now.
Old Oct 9, 2007 | 09:53 AM
WJ MARK's Avatar
What he said^^ if your looking for somthing that will hold lots of power a built TH-400 would be the way to go.
Old Oct 9, 2007 | 04:18 PM
but will it be better than putting a 700R4 because every 700R4 ive had has been a pain in my but
Old Oct 9, 2007 | 04:41 PM
Red04Silverado's Avatar
PM sent
Old Oct 9, 2007 | 05:55 PM
Grumpy5.3's Avatar
Whats your power rating??? A basically stock engine with boltons, you can get away with a 700-R4. But if you go with a 3speed, I would go with the
TH-350. Sure the 400 will hold more power, but unless you have a big-block with a blower and nitrous, the 400 will just cost you power. The internals are very heavy, and it would just be overkill. IMHO....
Old Oct 9, 2007 | 08:51 PM
im just going for about 400 Horses
Old Oct 9, 2007 | 09:14 PM
silveradol33's Avatar
I would go 700r4 you will hate not having overdrive, but if u are gonna go 3 speed, def the 350 cause you would loose so much power with the 400.
Old Oct 9, 2007 | 10:08 PM
I currently have the 700r4 built to the moon and I am VERY concerned that it will not hold. I will be making the swap. It not that it robs power it is the lower first gear that makes it seem that way.
