60 to 80 swap
Old Jan 27, 2011 | 03:07 PM
pitbull985's Avatar
you also have to do sum wiring i bought a harness from a 6.0 80e truck so it was plug and play only diff is the plug on the o2s
Old Jan 27, 2011 | 07:52 PM
Beatdown Z's Avatar
Laid Back
I went thru about 15 4L60Es before i went with an 80E..
I'm not going to make that mistake, my limit is five and I'm on number four, lol.
Old Jan 27, 2011 | 08:08 PM
Goose33's Avatar
Wow this is really helpful. Cost wise what's the comparison as far as use 60 vs 80?
Old Jan 27, 2011 | 08:53 PM
pitbull985's Avatar
80es are cheap but a stall for 1 is through the roof!!! lol
Old Jan 27, 2011 | 08:56 PM
Goose33's Avatar
Figures... But if you are goin do it right do it once haha
Old Jan 27, 2011 | 10:55 PM
fredkj3's Avatar
80e... NO REGRETS.. the guy is still driving mine with the 80e.... to me the little bit of loss is worth the insurance of a stronger trans.. although i liked the gearing... first was long but the others were all closer together... you wont regret it...
i had 2,000 in my swap.. thats with 1,000 in a tq converter
Old Jan 28, 2011 | 12:21 AM
Atomic's Avatar
I have a gauge for that
4L80E Swap
Trans cooler fittings -6an x 1/4nps $18
Additional Speed Sensor GM 24203876 $19
Speed Sensor Harness 2004sss $20
80e Dipstick Tube GM 15832205 $11
80e Dipstick GM 15183801 $35
Shifter Cable Bracket GM 15013290 $5
Bellhousing Cover Bolts (4) GM 11516328 $4
Bellhousing Cover GM 15765623 $64
Dshaft 5" 69 11/16" Texas DSS $620
PB 4l80e Performabuilt -
PB trade difference Performabuilt $920
Torque converter retrofit PI $400
TCI Flexplate 1slow01z71 - TCI-399753 $155
Offset Crossmember Bracket $40
Tcase Adapter 80e to np241 $95
Tcase Pump Saver Thing 4 wheel parts $30
Transfer Case Input tbtrans 42740 $105
Total: $2,541
Old Jan 28, 2011 | 08:52 AM
nonnieselman's Avatar
Thats a pretty good list right there.. mine cost me about $900 for everything.. i used the stock TC.
Old Jan 28, 2011 | 10:14 AM
00buckshot's Avatar
No problems since.. also a very hard shifting 60E will kill the output shaft very quick. that was one of my problems, i learned later on anyway.
The swap is very very simple..
All you need is a complete trans, TC, dipstick, shifter bracket and Flexplate for 80E.
Mod your Crossmember and bolt everything in,, get a TH400 Yoke and i think you have to get your DS shortened.
Wiring is easy..
https://www.performancetrucks.net/fo...d.php?t=413157
Waht he said x2, I went through at least 15-20 before i swapped, now i wish i had all my money back that i spent on that junk they call 4l60e
Old Jan 28, 2011 | 10:28 AM
Beatdown Z's Avatar
Laid Back
Originally Posted by Atomic
Total: $2,541
This is why everyone making good power should do the swap. My level 5 was $2500+, plus $615 for the torque converter, plus another $600 to have it rebuilt after I lost reverse a couple days after installing it.
