60 to 80 swap
First off I'm new to the site, my compliments from what i have read so far wow lots of info.
On to business i have a 05 Silverado 2wd std cab short wide bed 5.3, 4l60e trans w/transgo shift kit 3:73 rear end w/true trac, long tube headers, larger injectors, and a custom tune. 6 mths ago the out put shaft on the 60e broke, i replaced it with a built 65e now it broke. I dont want to waste more money on this trans, is the swap to a 4l80e the answer? Your input is welcome. Thanks Jeff |
Historically the 80e has far fewer problems than the 60e, especially behind some big power....but less guys have 80s than 60s... I just did the swap and am satisfied with it.
Done with the 4L65E
I'm on my third 65e, out put shaft breaks both times and i don't want to do this again. Unless i learn of something else its going to be the 80E swap. I have been reading on hear for hours still have not found the swap info I'm looking for. I'll keep reading.
Thanks for the input Guys Jeff |
Billet output shaft ? we have them....
Thanks for the info. i have to ask what is next to break in the 60? If i up grade the out put shaft is there other weak parts?
Originally Posted by JMF05LS
(Post 4617764)
(Post 4617764)
i just done the 80e swap and am pleased with it....worth the time and money to swap to know it wont break!
what ques do u have???
I went thru about 15 4L60Es before i went with an 80E..
No problems since.. also a very hard shifting 60E will kill the output shaft very quick. that was one of my problems, i learned later on anyway. The swap is very very simple.. All you need is a complete trans, TC, dipstick, shifter bracket and Flexplate for 80E. Mod your Crossmember and bolt everything in,, get a TH400 Yoke and i think you have to get your DS shortened. Wiring is easy.. https://www.performancetrucks.net/fo...d.php?t=413157 |
