4x4 4l80e output shaft????
Old Aug 27, 2009 | 01:24 PM
Wonderer876's Avatar
Default 4x4 4l80e output shaft????
I have to convert my 4l80e over to 4x4 from 2wd from a 4l60e. My question is would a stock replacement output be strong enough or should i go to an upgraded one? If i go stock ill just change the shaft in the transfer case and run about $200ish if i go with stock parts and the new shaft for the transfer case. The other one thru here http://www.transmissioncenter.net/4l80e.htm its about halfway down is an upgraded strength output with the right spline count to just hook the transfer case as is up, But is $355 fro the shaft alone. Opinions would be nice guys thanx
Old Aug 27, 2009 | 02:16 PM
KySilverado's Avatar
I'd do a stock 80e output shaft before the one linked and change the transfer case over. If major power I'd consider a billet 80e output shaft. Only 80e shaft I'm aware of being broke was Parish snapping an input shaft behind about a 1000/1000 power level.
Old Aug 27, 2009 | 03:58 PM
Hmm thank you, thats what i was lookin for. Just have to rebuild and wait for HPtuners to get back to my tuner on what needs to be done for the NNBS swap
kha4079
Oct 29, 2018 04:38 PM
gaps
Oct 15, 2015 02:53 PM
11MPG
Sep 8, 2015 04:52 AM
screaminian47
Sep 7, 2015 08:20 PM
mayko
Sep 7, 2015 12:24 PM
