4wd service light
Old Oct 17, 2007 | 12:48 PM
It will turn out to be the Sensor in the encoder motor. You can change the switch a hundred times and it'll work for a while but it will always go back to fail unless you change the sensor in the Transfer Case shift motor....dealers call it the Transfer Case Actuator.
The sensor part# you need is 88962315 and you'll also need the Actuator seal pant # 12384990.
Around $96.00 for the sensor. Most dealers stock it. I've done plenty of these operations. Trust me.
Old Oct 17, 2007 | 01:54 PM
TheChronic's Avatar
I'm not arguing your experience, but in my case I replaced the switch 4 years ago and haven't had a problem since.
Old Oct 17, 2007 | 02:24 PM
No problem bro,....just keep in mind that 4 years ago, the quick fix at all dealerships and garages was to replace the difital/analog switch which worked fine....for awhile. Now after a few years of research, GM has decided to produce a tech bulletin advising us that the position sensor i the actuator was the culprit. Some switches were bad...but keep in mind that if yours ever **** out again....replace the sensor and you'll be golden.
Old Oct 17, 2007 | 03:13 PM
pantz28's Avatar
Originally Posted by bowtiebandit
15709327 is the part number. Usually set a B2725 in the TCCM
Would I have to go to a dealer to have them read this, or could I do it at Pep Boys?
Old Oct 17, 2007 | 05:39 PM
N4cer's Avatar
10 Second Club
I would pull the switch apart so you can visually see the problem if it is indeed the switch. It's faster to fix it than it is to drive to the dealership.
Old Oct 17, 2007 | 06:04 PM
bowtiebandit's Avatar
A B2725 is a switch issue..bulletin on this also..Light on with no codes is a reprogram of the TCCM first..bulletin on this also.. There are a ton of bulletins out there for the NP8 transfer case..just depends on the code and the issue.
Choda
Jun 5, 2025 06:43 PM
carid
Oct 28, 2015 08:24 AM
Tydriver
45
Oct 23, 2015 09:19 PM
bluestang50
Sep 21, 2015 08:36 AM
fortune46x
Sep 16, 2015 08:18 AM
