4wd 4l80e in a 2wd
Old Jun 10, 2016 | 05:40 PM
Nwfjarhead's Avatar
Default 4wd 4l80e in a 2wd
Will it work? What's required to make it work? Is it worth it or should I keep looking? If not and someone can make use of it let me know. The guy is asking $150 OBO. Thanks for any advice.
Old Jun 10, 2016 | 06:05 PM
Wolftrk99's Avatar
If you have an output shaft and tail housing, and i do believe the 2wd you have to knock the plug out of the back of the trans.... And the 2wd has an oss on the side of the case the 4wd would have a plug for the hole in the place of the oss!! $150 whats wrong with it??
Old Jun 10, 2016 | 06:33 PM
Nwfjarhead's Avatar
Where can I get the output shaft and tail housing? What plug? What's a oss? Sorry for the newb questions but I'm not very knowledgeable with transmissions. If I was to pick it up I'll get the Jake's stage 5 rebuild keep so I won't have issues down the road. The guy said that the front seal went out on it. He said it was still operating properly when he pulled it after he wrecked the truck.
Old Jun 10, 2016 | 08:02 PM
Wolftrk99's Avatar
Find the tailshaft and output shaft used( i have them just need pull my 2wd apart to chabge out my tailshaft and get the busted 4wd off my front porch) the oss is output shaft speed sensor iss is input shaft speed sensor..
Old Jun 10, 2016 | 08:19 PM
tgui's Avatar
If you're willing to tear the trans apart then do it. I modded a 2wd 80e to 4wd, read my thread if you have the time.
One thing missed is the cup plug with tail oil hole, it needs to be plugged.
$150 is amazing and leaves room for a full rebuild IMO. Older, 93 or so need custom shift linkage bracket.
Old Jun 10, 2016 | 08:20 PM
tgui's Avatar
Oops! 4wd to 2wd! Plug needs hole. I have the 2wd output shaft and such if you want to make a deal.
Old Jun 10, 2016 | 08:22 PM
tgui's Avatar
I need to read, sounds like Wolfy has the parts too, ask him first.
Old Jun 10, 2016 | 08:52 PM
Flewbyu123's Avatar
Every one is forgetting the reluctor ring!
Old Jun 10, 2016 | 10:25 PM
Wolftrk99's Avatar
Reluctor ring?? Which one??
Old Jun 10, 2016 | 11:20 PM
Nwfjarhead's Avatar
I attached a link to the rebuild kit that I plan to get. It comes with intermediate and input shafts but I don't see any mention of a output shaft. If the kit is upgrading those shouldn't the output be upgraded as well or is a oem piece sufficient? What will I need in addition to the kit in order for it to be converted to a 2wd unit? Just the sensors and tail housing? I apologize for all of the newb questions, I just want to be clear on my parts list so I can drop everything off to my trans guy and he'll have everything he needs to build me a bulletproof trans.
Rebuild Kits ? Jake?s Performance
