4l80e wont do anything!
I'm done with the swap and now it will not do anything I pulled the cooler line off to see if it was pumping fluid and the trans is not pumping fluid so i dont know whether when i took the pump apart to put the spring in from p.i I pinched a oring or what i would think if i did that t would still pump a lil bit i just checked the distance from the bell housing and the converter pads and it's right at 1" so i dont think it is the converter anybody have any suggestions before i pull the trans out and take the front pump back apart?
nothin i took the front pump out and put the converter limit valve spring inside the one that was in it already justy like p.i instructed and then put a new gasket on the back of the pump and new oring around the pump and on the od shaft and bolted it back up. then i put the converter on the shaft and spun it till it clicked 3 times and bolted it to the motor then bolted it to the fly wheel and measured to make sure it was the right distance between the bellhousing and converter pads.
i dont know how it would have popped out i didnt mess with it but im taking the pump back out tommorow to see maybe its something simple if the pump was broke it would be leaking/ making a noise right?
iI have never seen a 4L80E that you put the convertor on and spin it till it clicks 3 times????? All I have seen are you have to install the converter with the 2 flat spots line up in the pump!! I may be wrong, never put a PI converter in one but...
Sometimes if you do not get the clip all the way installed in the groove it happens. Good to hear that you found your leak. Vince
i got it fixed then i drove it about 20 miles and it was driving fine till i pulled up to a stop sign and it will not pull off from stop signs anymore i'm just going to put a new front pump on it and see if that helps i think i hurt the stock one when was trouble shooting the no pressure problem.
BROKE-aSS-BLAZER
Oct 13, 2017 03:50 PM
jscherbs
Sep 30, 2015 07:54 AM
