4l80e valve body torque specs?
Old Nov 26, 2006 | 10:31 PM
Stoichiometric's Avatar
Default 4l80e valve body torque specs?
Anybody happen to know these off hand? Aslo, any luck re-using the pan gasket?
Thanks
Old Nov 26, 2006 | 11:03 PM
FLT's Avatar
FLT
FormerVendor
The torque spec's are 98-108 inlbs. If your pan gasket is plastic with rubber in the center of it than yes it is reusable. Vince
Old Nov 27, 2006 | 06:49 PM
Thanks Vince!
I thought of one more question after removing the valve body and seeing what the check ***** have been doing to the case and separator plate. Are Torlon plastic ***** OK to use instead of the stock steel ones?
Old Nov 27, 2006 | 08:10 PM
FLT's Avatar
FLT
FormerVendor
Yes the torlon ***** are very good. You might want to debur the case a little bit and get a new seperator plate.
lxcoupe
Aug 15, 2015 06:13 PM
NuckenFuts
Jul 9, 2015 08:45 AM
jrplz
Jul 9, 2015 12:07 AM
zaathur151
Jul 6, 2015 10:57 PM
