4L80e trans swap?
Old Apr 29, 2008 | 04:45 PM
gen3performance's Avatar
Default 4L80e trans swap?
I was just wondering if any 97 and newer 4l80e will bolt to an LS series engine? Or does it have to be a 97 and newer LS specific?
Old Apr 29, 2008 | 04:50 PM
thunder550's Avatar
High on diesel fumes
Nope, any of them will bolt up. The earlier models are missing the top center bolt flange but will still work.
Old Apr 29, 2008 | 04:53 PM
Can it be drilled out? or is there just not a flange there
Old Apr 29, 2008 | 05:00 PM
Stoichiometric's Avatar
The casting on the bellhousing is not flat where the bolt needs to go through. Seems like many have run the older trans without using the top bolt.
Old Apr 29, 2008 | 05:02 PM
ZZebes's Avatar
Top bolt not really necessary, hell i ran my 4l60e without one forever cause i'm lazy and have huge hands
Old Apr 29, 2008 | 05:54 PM
nonnieselman's Avatar
Basically all you need is the 4 bolts around the Dowel Pins....
Only reason i have 5 bolts in the 80E is cause i used one to put a zip tie on to hold some wires up and out of the way....
Old Jun 12, 2008 | 06:38 PM
What about electronics and harnesses. Will there be a problem if I use a 4l80e from a 1998 or a 1995. Or are they all the same.
Bumpers
Aug 4, 2024 09:44 PM
bighouse
Sep 27, 2015 12:37 AM
CammedZ71
Aug 2, 2015 01:44 AM
alex226
Jul 27, 2015 07:12 AM
lxcoupe
Jul 14, 2015 10:14 PM
