4l80e too cold?
Old Nov 1, 2011 | 08:11 PM
hvactech08's Avatar
Default 4l80e too cold?
is there such a thing as to cold of a tranny? i have a tru cool 40k on my 2500HD and the other night it dropped down to 30* and the tranny got to 105 after driving for like 45 min at night.
I was also wandering if the intake temps can be too cold? i had 34* that same night reading from the MAF
Old Nov 1, 2011 | 08:40 PM
Suburbazine's Avatar
The cooler the better. Only risk with cold air is that if you have bypassed the throttle heater the blade can freeze open.
105 isn't a bad temp for the transmission- it may make TCC lockup not happen though.
Old Nov 1, 2011 | 09:14 PM
Coban's Avatar
I'll just say, GM Engineers designed the cooler to be the size it is for a reason....
Old Nov 1, 2011 | 11:18 PM
They put catalytic converters, baffled muffler and 85% torque management on it for a reason too. Just saying...
The fluid is designed to work optimally from 90-160 degrees or so. Engine oil is much the same way. Now running an engine at 105 degrees has it's obvious drawbacks, including but not limited to seals, rings, and metal deterioration, but the transmission is perfectly happy if it sits around 120* or so and I'm sure the builder would be happy with that number too. Speaking of which, lets ask a builder!
Old Nov 1, 2011 | 11:31 PM
AKlowriderZ71's Avatar
11 Second Hall Moniter
TCC lockup is allowed around 78* if I remember correctly. Don't worry about trans temps being too cold, unless you are talking about well below 0*F.
Old Nov 2, 2011 | 05:11 AM
Vince B's Avatar
Once the trans fluid temp gets to 68* the tcc will then be able to lockup. If its taking to long to reach this then tying the cooler lines back into the radiator first and then into the external cooler might not be a bad idea for the winter months.
Old Nov 2, 2011 | 08:03 AM
Coban's Avatar
Yea, different reasons.... and I doubt you'd want to be stuck in a traffic jam where all the cars did not have mufflers or catalytic converters....
What's the boiling point of water again???
Old Nov 2, 2011 | 09:07 AM
hvactech08's Avatar
I am gonna buy a new stall here soon and think that it should help warm the tranny up a lil.
I never got it over 155 even in 95* days
Old Nov 2, 2011 | 12:41 PM
slow67's Avatar
Gingervitis Addict
I thought the Trucool cooler had a built in thermostat?
Old Nov 2, 2011 | 12:54 PM
Not exactly a thermostat, but this pic explains it best.
